Switching from Drive to Neutral in '94 auto.
I often switch from D to N when coasting down a hill or approaching a red light. Anything wrong with this? Could switching from N to D be bad for the transmission?
It feels very smooth when I do it, and I'm getting much better mileage.
Thanks for your input,
-Sam
-Sam
Have you checked the owner's manual for a comment that goes: "Do not place in N while car is moving" or "Do not coast in N for extended periods" or something to that effect? If not I might guess it'd be alright if nothing jolts or anything (like when you re-engage D). Just don't shut off the engine for that extra 1 mpg!
Re: Switching from Drive to Neutral in '94 auto.
-Sam
-Sam
There are other ways to save on gas mileage. It's important to save those pennies when you go to the pump right now, with prices as high as they are, but putting your car into neutral to coast down every hill and back into drive over and over again is gonna cost you way more than you're going to save.
Keeping up on general maintenance is by far the best way to maintain healthy and affordable gas mileage.
Re: Re: Switching from Drive to Neutral in '94 auto.
Originally posted by nismo1989
You will screw your already weak tranny...
What kind of maintenance are you suggesting? I change the oil and check all the fluid levels, and maintain good tire pressure, and that's about it.
-Sam
Re: Re: Re: Switching from Drive to Neutral in '94 auto.
Originally posted by Taegost
Doesn't the tranny automatically disengage the clutch when you're coasting, much the same as going D-N-D?
and Sam: You're getting all the basics pretty well, but don't forget your intake (air filter, throttle body, etc.) or your ignition system (plugs, wires, cap, rotor, etc.). Also, routine fuel system cleanings can do wonders on our old engines. Not the stuff of the shelf you add to your tank, either. You don't want those over the counter detergents mixing in your gas tank becuase they settle there. Get a professional fuel system cleaning done. Go to your local Nissan dealer and ask about a fuel system cleaning. Should cost $100-$150, but it's well worth it.
Re: Re: Re: Re: Switching from Drive to Neutral in '94 auto.
No, it is not the same as taking it completely out of drive and then putting it back in drive while it's moving. I don't usually do that in my car and it's a 5spd...
Brakes are cheaper in that instance, but thank you for enlightening me on that, I knew it disengaged it, but I wasn't sure if it was the same or not.
I don't think it is, at least not with my car. When I switch from D to N, the RPM's go down, and I coast much much smoother (less decelleration than just coasting, which slows down due to gear friction I suppose).
-Sam
And thanks a lot for all the information you've provided, I appreciate it.
-Sam
Re: Re: Re: Re: Re: Switching from Drive to Neutral in '94 auto.
Does jiffy lube do it?
-Sam
-Sam
yeah jiffy does it, they will do it for around 30 or 40 bucks or so.
Re: Re: Re: Re: Re: Re: Switching from Drive to Neutral in '94 auto.
hey guys,
My max will shift from drive into neutral w/o me applying the brake, I can just push the shifter into neutral as I'm moving. Is this normal, do your cars do this?
Re: Re: Re: Re: Re: Re: Re: Switching from Drive to Neutral in '94 auto.
normal as far as I know, mine does it too.
Originally posted by molehill84
hey guys,
hey guys,
Re: Re: Re: Re: Re: Re: Re: Re: Switching from Drive to Neutral in '94 auto.
Alright, thanks DA-MAX, the first time it happened I was like, "God, that can't be good." I'm glad it's a normal thing.
I love manual transmitions.
The reason it seems this way is becuase an automatic transmition doesn't have "engine braking", like when you take a turn fast in an automatic and you have to tap the brakes going into the apex of the curve. You don't have the engine braking for you. This is why you see so many Suburbans in front of you in rush hour on the highway tapping thier brakes for seemingly no reason. If they don't thier inertia will keep them going until they rearend whatever is in front of them...
Originally posted by mykizism
SHut up you read that out of turbo magazine quit plagarizing other people`s work.
WTF do you know anyway?? I said nothing to warrant you starting **** with me so watch yoursef, pal. Not sure what you suddenly have against me but whatever...
LOL!!
this is not good... saying "shut up" was not cool at all,
- back on the topic: i always put my tranny into N and rev around... I have been doing this for a long time (4 months), i dont abuse the tranny shifts on drive though... i have never brake torqued it and never N droped it.. tranny still feels liek new.. (82k)
hey guys,
hey guys,
You can go from R-N also, but NOT from N-R without the button.
Personally I wouldn't do that, and I don't really understand how it saves you a noticable amount in gas milage. When coasting down a hill the torque convertor will disengage, letting it coast anyways. PUtting it back into drive from neutral when you are moving seems like it would be really hard on your tranny.
I don't even read whatever magazine and you shut the *** up you stupid punk.
i dont know anything obviously, but if u want me to go scan that page where you got that from, its fine with me.
