timing belt replacement prices
don't buy cheap parts....if you do you're asking for trouble...
BUY OEM...parts should run you ~$200 for everything you need and if you can't do it yourself you're looking at $200-$400 in labor depending on who does it
Here's a link:
http://www.courtesyparts.com/cgi-bin..._oem_60k-vg30e
Get the timing belt, water pump, timing belt tensioner, front crank and cam seals, and a thermostat. You'll also need some silicon gasket.
Good luck.
-Kaleb
Good luck.
-Kaleb
Maxima2010 Prem
08-13-2015 11:34 AM
