NEED *** ECU CODES *** for 92 SE Auto
I suggest buying a service manual for about the same price. it will have all the ECU codes in there, and you'll be able to fix and diagnose so much more later also.
An essential tool in the garage if you maintain your car yourself.
Originally posted by exco_05
hey on saturday i can get them for you i will be in the shop and i will get the code page(s) for you
OK do this. Turn the ignition key on (car not running) take the panel on the passenger side of the car under the radio off. turn the little screw fully clockwise then turn back. watch the bulbs flash the haynes manual says that a red one will flash the first code and a green light will flash a second code but mine only has the red light and it flashes the first code then waits and flashes the second code.
come back on here and tell us the code and we will tell you what it means.
it is too hard to post all the codes.
It would be good if you could at least get a cheap haynes manual...it will help in the long run.
good luck and let us know.
Originally posted by wojtekj
I wish i could buy the manual but they don't have any for 92+ SE, I live in Toronto, Canada. I know it sucks. If someone has instructions how to get the code lights going at least appreciate it.
email me the code or post it here and I will tell you what it means.
good luck,
I've checked the ECU codes and there is one red light flashing.
Don't forget it's 92 SE.
I counted 5 longer flashes and 5 shorter flashes.
Can anyone tell me what that means?
I ran the test and got the same thing and my car runs smooth as silk except for the occasional tick (dang vtc) every now and then.
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
220k+ A32
09-22-2015 03:08 PM
QueensMAX
09-15-2015 04:14 AM
