Serious Maximanian needs help!!
Old May 23, 2002 | 10:19 AM
hclll's Avatar
My maxima sometimes has problem when stopping at a light. The tachometer niddle will jump up and down. It even down to 400rpm, the engine is struggling from coming into a stall. But if the AC is on, this problem never happens.
It is not a dirty throttle body or fuel injector. Must be something related to thermal. I remember somebody talked about it before, but I could not find the post.
Please help!!!
Old May 23, 2002 | 10:26 AM
time2reup's Avatar
Plugs and wires
When is the last time you replaced these?
Old May 23, 2002 | 10:33 AM
hclll's Avatar
pulg wires are fine
I didn't replace them, but tested the resistance of each. I got 3 of them 13K ohm, other 3 are: 10K,8.5K, 7K. IT looks normal.
The only thing I did to ignition is replacing Idstributor cap. It was a $19 one bought from Autozone. Is that a problem?
Old May 23, 2002 | 10:35 AM
exco_05's Avatar
Re: Serious Maximanian needs help!!
Please help!!!
try your throttle position sensor
Old May 23, 2002 | 10:38 AM
hclll's Avatar
where is it?
Old May 23, 2002 | 10:42 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: where is it?
TPS - opposite side of the throttle cable on the throttle body.
black rectangle w/ wires coming out of it.
Old May 23, 2002 | 02:56 PM
hooptey's Avatar
I had the same problem and I replaced the throttle position sensor and it fixed it right up.
Old May 23, 2002 | 03:26 PM
White93SE's Avatar
Please help!!!
O2 sensor
Old May 24, 2002 | 05:39 AM
phat's Avatar
Why don't u try and replace the distributor rotor and the plugs before u replace the tps? Just replacing the distributor is only half the job. its like taking a shower without using soap.
If the plugs and the rotor is not the problem, u just did a tune up and its not that costly. If the tps is bad, wouldn't it do the same thing with or without a/c being on?
litch
123
Jan 4, 2024 07:01 PM
02PearlSE
Feb 1, 2016 12:37 AM
TxBroncosFan
Sep 21, 2015 06:54 PM
doctorpullit
Sep 5, 2015 04:40 AM
