antenna replacement
Old May 27, 2002 | 04:00 PM
surfermax92's Avatar
antenna replacement
My power antenna would not go down, so I followed the instructions on the gen34mg site and opened the spool up. I was unable to find the expected broken piece of mast- instead it was a little bit kinked. I then unspooled the plastic wire and tried to feed it back in, but it wouldn't go. I think that the motor might be messed up, and I just want to ditch it. I get reception without the power antenna because of the rear window antenna, so do I need to replace the long one? If so, can I just install one of the short ones like skymax's? Thanks for the help and sorry this is so long.
Miles
Old May 27, 2002 | 11:52 PM
bump
Old May 28, 2002 | 10:36 AM
tilt's Avatar
If you take the cover off the motor, there will be a small white plastic gear looking thing. Take that out and you can spool it back in then put the plastic thing back in place. Maybe what is happening is the teeth are stripped on your antenna mast? Maybe some extra grease will help. Just a thought.
Old May 28, 2002 | 05:40 PM
The only thing that makes me think differently is that the motor started squeaking when going up or down about a week before I took it out. I think that it may be shot- so I'd rather go for a small stick-on antenna if possible. Thanks for the idea though.
Old May 29, 2002 | 12:19 AM
kingrye's Avatar
yea i had the same problem so i put on the zendar flex fifty it looks like a focus or bug antenna prety cool and not overly ricey
Old May 29, 2002 | 11:31 PM
1. How did you wire the new antenna, 2. How was the reception, and 3. what did you do with the opening for the old antenna? Thanks for the help
Miles
Old May 30, 2002 | 12:08 AM
mykizism's Avatar
Re: antenna replacement
Miles
when you feed the mast back in.. are you doing it when the motor is trying to pull it down? ie: turning on the radio first, then insert the mast, then turn the radio off (then start feeding the mast down as the motor is pulling it back in)
b/c you cant force the mast down
Old May 30, 2002 | 05:34 AM
Jaybird180's Avatar
Miles
I need to do an antenna replacement. Where is this gen34mg site, and what rear window antenna?
Old May 30, 2002 | 09:34 AM
«§»Craig B«§»'s Avatar
Re: Re: antenna replacement
I know Chris has posted the link many times before
Old May 30, 2002 | 02:04 PM
I did try to feed the antenna back down when I turned the radio off. It just felt as if it hit a solid block and would not continue down. I rotated it all around but could not get it to go in. I don't really mind because I like the look of the whip antennas better, I just don't know how to wire them and what to do with the old one.
Old May 30, 2002 | 04:52 PM
joebleu's Avatar
Re: Re: Re: antenna replacement
Hi all... i'm new to this forum...
I searched for that site as you've suggested... but there is not thread found with this keyword... my rear antenna doesn't come up all the way... It would come partway up and then stop... when I turn off the radio, it would go part way and then the motor would keep making noise but the antenna won't go down =(
I just got my maxima (93 GXE and loving it... but i would like to get this fixed... also... what other cool sites can i find info and mod for the 3rd generations?)
Old May 30, 2002 | 04:57 PM
Re: Re: Re: Re: antenna replacement
hey joe, welcome
since you're new, I'll help you out
http://www.gen3.4mg.com/cgi-bin/fram...r_antenna.html
check out my site:
http://www.prism.gatech.edu/~gte671n/mymax.html
it has some interesting stuff in the how-to, also, check out the links page on it, I have links to many other useful maxima pages
for more maxima pics, go to maxima.cardomain.com
also, read the "Important: ATTN NEW MEMBERS" post at the top of this forum
enjoy the max
Old May 30, 2002 | 05:00 PM
joebleu's Avatar
cool.. i'll check those links out and the newbie thread =) thanks!
Old May 30, 2002 | 05:03 PM
Jaybird180's Avatar
Re: Re: Re: Re: Re: antenna replacement
I guess if I were new I'd have gotten the same answer!?!?!
hey joe, welcome
check out my site:
enjoy the max
Old May 31, 2002 | 05:30 AM
Re: Re: Re: Re: Re: Re: antenna replacement
if I remember correctly, you've been around since late 2000, sometime around November I think
I know you've only made somewhere between 150-200 posts but you know how things work around here
and I dont like the Kansas Jayhawks (your name reminded me of them)
Old May 31, 2002 | 06:11 AM
Mikey P's Avatar
Re: Re: Re: Re: Re: Re: Re: antenna replacement
ha, touche!
Old May 31, 2002 | 01:34 PM
Jaybird180's Avatar
You read my profile and tried to make it to appear that you had that good of a memory. I'm honored, sir.
Old May 31, 2002 | 01:47 PM
Re: Re: Re: Re: Re: Re: Re: Re: antenna replacement
what? there is a profile with all that info?
I guess I can get rid of all these charts adn graphs I have been making
can you show me the profile link that you're referring to?
thanks
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
