Thermostat replacement
Old May 31, 2002 | 07:03 AM
KCMax's Avatar
My car is not overheating, but when I park the thing, it's spitting up fluid from the resevoir. I asked the dealer and he said that the thermostat might be sticking on and it's building up pressure in the system and releasing it through the resevoir. What do you guys think?
Also, on a 1 to 10 scale (10 highest) how difficult is it to replace the thermostat? Thanks!
Old May 31, 2002 | 11:07 AM
blackandwhite's Avatar
To them I'm like an idol
Re: Thermostat replacement
Drain the coolant, take the 2 hose off the thermostat housing, take the housing off (3 or 4 bolts, one is very hard to get to, I'd jack up the passenger side and take the tire off for extra room), replace thermostat, use rtv blue sealant on the housing, and bolt it back on, and refill coolant.
Old May 31, 2002 | 11:11 AM
KCMax's Avatar
You make is sound so damn easy!
Old May 31, 2002 | 11:27 AM
jp91se's Avatar
damn you experienced people!
Old May 31, 2002 | 11:54 AM
That's because it
It is not very hard, the whole thing took me 2 hours, but about 45 minutes of that was wasted trying to use the wrong tools to remove one of the hose clamps, that was turned away from me.
Somebody who know what they are doing (unlike I did at the time), could probably do it in an hour. And they wouldn't have forgotten to drain the coolant first, and made a huge mess either.
Get a manual chilton's,haynes, or FSM. I suggest all 3.
Old May 31, 2002 | 01:25 PM
Taegost's Avatar
Re: That's because it
That long? I watched my g/fs father do it in about 15 minutes using just a socket set... After we spent an hour and a half draining the fluid because it was a 30/70 mixture of rust/water
Old May 31, 2002 | 01:35 PM
Re: Re: That's because it
Well, I spend about 45 minutes trying to get a hose clamp off with a broken pair of needle nose pliers. Then, I spent another 30 minutes cleaning up coolant because I didn't drain it first.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
