UDP Undrive Pulley
Go to my site and you can read a complete writeup I did on the UDP. http://grprete.jnet.net
In short, it is a cheap easy mod to do - worth about 5-7 hp. Yes, you can feel the difference. Primarily it adds low-end torque.
I've had it since October 1999 with no problems.
Originally posted by DaEnigma
I got mine and felt the difference off of the line...
For $167 I think it is worth it btw I got mine from Stillen...
Does it really add low-end power and are u able to feel it? I am thinking about buying one soon.
UDP was my first mod (along with CAI). The combo of the two really helps the low end torque. You CAN feel it.
Your y-pipe and exhaust helped with high end HP and passing speeds. Now add more pull off the line.
I've got so much torque I'm running 0-60mph in 6.4s - and those are rough launches. I haven't even timed yet with the new y-pipe and my b-pipe (installing today)
You need new belts, part #s come with it
I haven't noticed any difference with a/c or other systems... I haven't noticed any speed either.
Originally posted by Southpaw17
hey, i was thinking of getting one but i heard it messes with the ac and other things, i dont use the ac regardless but what are the draw backs? and do u have to have new belts with it?
DEBO
DEBO
Well what i heard is that the udp frees up engine power but takes away from electrical power,but if gains is what your looking for then why not get it and while your at it get a lighter flywheel along with the unp to really crank up your acceleration.
Originally posted by Surge Diesal
Not worth the money for only 3-4hp. Take your cash and buy yourself a shiftknob, pedal kit, dash trim, interior lights, and clear corners. You'll find the hp gain is about the same.
HP gain from a pedal and dash kit?
well. Any gains for the engine is well worth it in the long run. i mean, if you're going to go all out, you have to get the little pieces that all come into place at the end..
i'd rather go for power, than for simple looks.
My A/C suffered with the UDP. It just doesn't have the cold oomph to cool the car as fast. I saw the diff within weeks of installing so I doubt it was the refrigerant.
Somebody warned that the lighter flywheel screwed up the cruise control. Because of the faster acceleration it kept kicking the throttle in & out or something. Just something I heard.
Originally posted by fcuco
I'm debating if I should purchase a Undrive Pulley for my 1996 Maxima...Is it worth the investment? Impressions anyone? Thanks..
Usual mods Y-Pipe,exhaust, intake, etc..
Fernando
Fernando
The more mods I get, the more I want! I haven't been disappointed with any of my mods so far... Knock on wood.
so what r the final costs w/ pulley belts and install i need numbers here people.
DEBO
DEBO
rbarnes
Dec 31, 2015 06:29 PM
