Need help: leatherseats.com install
I started doing my install last night. Got the back seats done no problem, they look real nice. Started working on the front passenger seat. Got the bottom half (where your butt goes) all finished. I then started working on the upper half (where your back rests) and I got kind of stuck. I got the cover over the seat and sitting properly, but I cant figure out how the hell youre supposed to get the hog rings in (where the two-tone color is in the center of the seat). I tried to slide my arm up the front of the seat and put one in but its to tight. Am I doing something wrong? I cant see how you could do it any other way....you have to put the whole cover over the seat, so its unlike all the other hog ring areas where you have easy access. Please be specific with any replies. Thanks
shaz
shaz
Re: Re: Need help: leatherseats.com install
Originally posted by maxi98
have another person push down the leather so u can clip to the foam.. and wait till u try to zip the cover... use brutal force, the leather is tougher than u think~~~~ have fun!!!
Also, is it normal for there to be a small gap (maybe an inch) where the lower part of the seat meets the upper part? its only noticable from an angle if the seat is leaning back
shaz
Re: Re: Re: Need help: leatherseats.com install
there is a gap, happens on mine~~ and like i said, have another person pushes down the leather so u can concentrate on clipping the leather. as for the zipper, the space is very very limited, so use brutal force
Thanks for all the advice guys, I finally got the passenger seat done, looks really nice. Now all i gotta do is the drivers seat, but I gotta wait till I can get someone over to help cause I gotta do it all in one shot.
I think I must be retarded cause the only other problem I had was putting the rear center console back in. I had it sitting out so long I forget how it went back together. I've got 4 bolts sitting around but no screws for them. i guess I'll figure it out eventually
shaz
shaz
MaxLife17
06-27-2019 01:37 PM
