Problem With ECU? Help!
Old Aug 24, 2002 | 08:37 PM
JetBlackMax's Avatar
Hey guys. Well I changed my Spark Plugs and after that was done, the Check Engine Light popped on. So I read the procedure on how to do it. I did exactly what it said, but it still wont turn off.
Heres what I did.
I had the car off and everything, no key in the ignition. Turned the screw clockwise until stop, waited 2 seconds, turning it back to counterclockwise until stop, and did it again real quick.
Am I doing something wrong? this light is killin me! lol
Any info i would appreciate!, thanx!
Old Aug 24, 2002 | 08:52 PM
Im sittin here I need Help! LOL please anyone
Old Aug 24, 2002 | 09:11 PM
gepetto's Avatar
ummm...the engine light is sposed to stay on if you leave the car in "acc" but dont crank and turn it over . turn the engine on and itll go away. if not, you still have the problem. did you get the code from the light before you reset it?
Old Aug 24, 2002 | 09:48 PM
meccanoble's Avatar
Sports Button FTW
Re: Problem With ECU? Help!
Heres what I did.
ehh, first off, u r SUPPOSED to have the car on the dial right before it can be started. Then u do the reset. That may be your mistake right there. If that doesn't work, then check the codes they give you and work from there. But car has to be on AC or lock on, not sure what name is but the one before car can be started....
Old Aug 25, 2002 | 02:19 PM
gepetto's Avatar
when you car is in the "lock" position and the ac and radio come on, all your dash lights come on (ebrake, airbag, CEL etc etc). once the engine turns over. they all go off.
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
mix master
Sep 4, 2015 05:50 PM
