Start the car... RPM=15000 ... why is that?
Old Aug 30, 2002 | 08:10 PM
Sexima's Avatar
WHY WHY WHY?!?!?!
It idles too high...
I have no idea why
Old Aug 30, 2002 | 08:18 PM
sil SE's Avatar
you mean 1500 man?
i think i get that too. it starts at like 1200 or 1300 then it calms to 6-700 later on.
Old Aug 30, 2002 | 09:42 PM
WaarrEagle's Avatar
The idle is high when the car first starts because it is trying to warm the engine up. Let the car warm up and check it. It should be at 700 with the a/c OFF. If it is not where it needs to be there is an idle adjustment screw under the hood.
Old Aug 30, 2002 | 11:08 PM
Toolrocks's Avatar
Yeah sexima, it's just the car trying to warm up to operating temp. As you know it's a little cooler around here so your car is starting at a cooler temp when compared to a few days ago (the car was closer to its operating temp when it was hot outside). I mention that in case this just happened and has you concerned. Last week mine was starting at around 1200 and then dropping to 700 or so. The last two days it has started and revved at around 1500 and then drops to about 1200 for a few secs and then finally down to 700. All is normal.
Old Aug 30, 2002 | 11:32 PM
NotNew!!NewSN!!'s Avatar
man 15000 rpms is awesome, u basically have an indy car, mine only goes to 6.5k rpms
Old Aug 31, 2002 | 02:25 PM
Sexima's Avatar
ah.. ic....
whew.. i thought my car was going to blow up or something...
Old Aug 31, 2002 | 02:36 PM
venompwr2's Avatar
he said 1,500 not 15,000....read carefully...the S2000 doesnt even rev that high
Old Aug 31, 2002 | 03:13 PM
henock
This may be related to my remote starter problem.
When the engine is cold it revs up automatically, like you said, and when it is warm it stays low.
My problem:
I have an Audiovox. Whenever the car is cold and I start the car with the remote, it cranks and cranks for about 5 seconds then gives up.. waits 5 seconds, tries again, and works just fine.
I took my car back to circuit city a few times and they said that the remote starter would stop trying to crank the car once it hits a certain RPM.. Hence the cold start problems would have to do with the RPM that needs to be detected.. which is too high.
THe last time i took my car over to CC they adjusted via the alarm the RPM# to shut off at. They told me if it still dosent work, then the car may need a tune up. Would that sound accurate to you guys? any advice?
i'm a 97gxe auto with 99k miles.
Old Aug 31, 2002 | 04:06 PM
Toolrocks's Avatar
henock, your car will only rev that high when it is running. When the car is cranking the starter can only rotate the engine around 300-400 rpms. The car then kicks over and revs up higher. The reason your car wont start right away when cold probably isn't due to the remote start. You would probably experience the same problem if you started it w/ your key. In that case, a tune up may help.
Old Aug 31, 2002 | 05:40 PM
henock
Hey Toolrocks, thanks for the info
If i start the car cold with my key it works just fine, barely any cranking involed. So... What does a tuneup entail?
Old Aug 31, 2002 | 05:54 PM
Toolrocks's Avatar
Well, if that's the case then what I'm thinking is wrong unless you turn the key slowly. I was thinking that there wasn't enough pressure in the fuel system and when the remote start went to cranking the engine it took a few seconds for the fuel pump to build the pressure up before it could start. If you're turning your key somewhat slowyly you're giving the fuel pump a second or two to pressurize the system. If you're turning the key quickly then I don't know what to say. The remote start should simulate the conditions that exist when you turn the key.
As for the tune up question; depending on your mileage, a tune up usually includes inspecting and maybe replacing plugs, air filter, fuel filter, pcv valve, oil/filter, etc. I'd get a Haynes or Chilton manual if I were you. Good luck and keep the questions comming if you have more.
Old Aug 31, 2002 | 06:01 PM
nadir_s's Avatar
vicodin ... gift of life
he was jokin, get w/ it man!
Old Aug 31, 2002 | 07:57 PM
BluFlame's Avatar
/* Start the car... RPM=15000 ... why is that? */
he said 15,000.
Old Aug 31, 2002 | 11:26 PM
Sexima's Avatar
a little accident. im so sorry
Old Sep 1, 2002 | 06:49 PM
thank god you picked up on that, i was about to tear this kid a new one for tryin to be a smarta$$, and if ur gonna compare redlines done use an s2000, big deal it goes to 8900 rpms, woopty friggin do. Rx-8 is supposed to eventually be redlining at 10
Old Sep 2, 2002 | 01:23 PM
Kevlo911's Avatar
Kevlo for President
on a cold start mine goes like 1500 -1300 -1200, when its warm 600-800
mvm062
Nov 30, 2020 09:00 AM
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
