Tips on a Smoother Ride
Old Aug 31, 2002 | 08:54 PM
nismoflo's Avatar
I have a 1995 Maxima and the ride is really bumpy. The streets where I live are not that bad but, I feel every bump I go over. I was wondering if anyone had any tips on how to make the ride smoother. Thnx
-Nismoflo
Old Aug 31, 2002 | 10:27 PM
Sin's Avatar
Sin
Re: Tips on a Smoother Ride
-Nismoflo
Maybe your shocks are toast?
Old Aug 31, 2002 | 10:36 PM
97GLE's Avatar
-Nismoflo
How old is your car, how many miles, and do you have any modifications.
Old Aug 31, 2002 | 10:44 PM
meccanoble's Avatar
Sports Button FTW
i would definitely recommend getting new shocks, aftermarket in fact (KYB AGX)...that should definitely stiffen up your ride and make sure u have enough air in your tires
Old Sep 1, 2002 | 01:20 AM
spiff56747's Avatar
KYB AGX should definetely stiffen up your ride, but he said he wanted it to be more smooth.
He probably just needs some new OEM shocks installed.
Old Sep 1, 2002 | 01:28 AM
TurDz's Avatar
A few suggestions:
Try searching the user, njmaxseltd, and look for some of his posts on using intake manifold gasket material rather than the paper thin strut mount gasket.
Actually, I found it for you:
http://forums.maxima.org/showthread....ghlight=gasket
Also, tire pressure plays a large role in ride quality as someone mentioned. Experiment with ranges from 30-35 and find the pressure best suited for you. Pump up the fronts 1-2 psi more than the rears.
Old Sep 1, 2002 | 03:21 AM
$tillen$ux's Avatar
would the warpspeed subframe connectors keep the cheap-o rattles out? maybe thatll give you a more solid ride
Old Sep 1, 2002 | 06:40 AM
njmaxseltd's Avatar
-Nismoflo
He want's a smoother ride.
Assuming you have the OEM suspension still in your car it may be time to replace your front struts and rear shocks. If you want that smooth new car ride back, go get yourself a set of Tokico Blue Performance Struts and Shocks. Don't go with AGX, there a bit firm and valved for performance applications. They are excellent struts but may be a bit harder then what your looking for.
The Tokico Blues work excellent with OEM springs. They absorb bumps very well and give you that new car ride back.
Old Sep 3, 2002 | 05:49 AM
Chillin's Avatar
Re: Re: Tips on a Smoother Ride
How much does the Tokico Blue Performance struts and shocks usually cost? Is it a do-it-yourself job? Also earlier in a thread I read where someone mentioned something about a rattle... I get a rattle sound everytime i go over a bump. Any ideas.
Old Sep 4, 2002 | 12:50 AM
nismoflo's Avatar
I have a 1995 maxima with 100k miles. And there isnt any modifications to the car performancewise yet. I am the only owner so I know everything is stock.
thnx
-nismoflo
Old Sep 4, 2002 | 04:41 AM
95Max's Avatar
I would not go with the Tokico Blues. I had them on my stock suspension and didn't think they were that great. FYI, when I replace the suspension the driver front strut (Tokico blue) was noticeably softer than the passenger side. No wonder the car handled like crap. Anyway save the $$$ and go with KYB Gr-2.
Old Sep 4, 2002 | 05:16 AM
Albertt's Avatar
Want a smooth ride >>
Stick with the stock springs, install KYB GR-2s and make sure you replace the strut bearings and the related hardware.
Old Sep 4, 2002 | 06:06 AM
Chillin's Avatar
What?
So what is best for a smooth ride. And do you know this from experience or just basic knowledge of the product.
Old Sep 4, 2002 | 06:36 AM
tiedyemaxima
ok...I'm masking as this person because they used this comp last and I don't know them, but luckily...I have a nissan altima that I'm workin on(slowly)...so if this person could give me some pointers as a nissan person... my email is: jason.prock@us.army.mil
I'm sorry I used your name and if u want to send me a full out e-mail of threats and cursing...well whatever..., and anyone else who sees this and would like to contribute info and suggestions, please do.
Old Sep 4, 2002 | 06:38 AM
Roman-dude's Avatar
-Nismoflo
I have a solution that will cost you the least- just put a good pillow under your a$$!
Take care!
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
