Does Place Racing CAI get wet in the rain?
Old Sep 17, 2002 | 06:07 AM
Hot99Max's Avatar
I was driving home from Penn on Sunday night in heavy rain. As I was driving, I heard a "gurgle" type noise coming from under the hood. Naturally of course I freaked out thinking that I got water in the engine bay. I stopped twice at two different gas stations to check the noise....everything sounded normal. Engine reved with no problems. So I continued on my way back to Mass. Again I was drving at about 60 mph because of the low visability and I was getting passed by speeding tractor trailer trucks and they were splashing some serious water onto the front of my car on top of the water already falling from the sky. Again on several occasion that "gurgle" noise came on whenever I accelerated. It would last for a few seconds and then it would go away.
My thing is this...the guy who installed by intake told me that I should not drive it it the rain because it will get wet. I can't see who this is possible. I have a Stillen body kit and the air filter is covered from the bottom, the top, and in the front.
Needless to say I did make it home safely and my engine still sounds and performs normally. Is this something I should worry about or am I just overacting
? Do I really need to move the air filter to the engine bay everytime it rains?
Old Sep 17, 2002 | 06:19 AM
abstrakt79's Avatar
Hey check this thread out, if your really worried, you could try the bypass valve. Hope it helps http://forums.maxima.org/showthread....ight=CAI+water
Old Sep 17, 2002 | 08:53 AM
MardiGrasMax's Avatar
I caught the same rain on Sunday in PA on I84. That was very heavy rain and not normal at all. I had to slow down to 40mph a few time is was so bad.
The filter will get wet, even soaked, but as long as the pipe is not completely submurged you should be ok. A little water mist going into a motor under cruising load wont hurt a thing. It may even help clean out some of the carbon build up on the valves, and combustion chamber etc.
I dont have a cat. convertor and havent gotten a code for it in quite a while. Well Sunday after an hour in that rain I got the code again. I assume that the water and steam cleaned every thing up and the car is running closer to optimum so the ECU can detect that I dont have a cat. I reset the code yesterday and it came back after a few hunderd miles.
So to summarize, dont sweat the rain. Watch for the deep puddles!
Old Sep 17, 2002 | 01:46 PM
96shogunmax's Avatar
getting alot of posts about this question. dont worry a bit i have the same thing. ride in rain all the time. just dont go in a lake. your ok
Old Sep 17, 2002 | 04:36 PM
sryth's Avatar
I still concur
-Sryth...
__________________________________________________ ____________________________
'98 SE 5spd, Pebble Beige, PRCAI, Stillen Y, Stillen FSTB, ACT clutch.
Pacesetter STS to be installed this week!
Old Sep 17, 2002 | 06:31 PM
Originally posted by sryth
I still concur
-Sryth...
once again......
Old Sep 17, 2002 | 06:52 PM
Jr'sMaxima's Avatar
Same here!
Old Sep 17, 2002 | 06:57 PM
MAXSRB's Avatar
On a related topic where can i get just the upper intake piping from the place racing CAI kit? (The piping from the MAF to the TB) thats all i want since i already bought a cone and i doubt the cone will fit in my fender. Thanks
Old Sep 17, 2002 | 08:04 PM
Once Again Place Racing # 626-334-3345 and Cattman # 1-800-795-1513
i think this should be a FAQ!!! What do you guys think?(the whole water in CAI thing)
Old Sep 17, 2002 | 08:15 PM
MAXSRB's Avatar
Thanks.
Old Sep 17, 2002 | 08:42 PM
Thanks.
no problem....
Old Sep 17, 2002 | 09:16 PM
sryth's Avatar
A lot of things should be in the FAQ, but aren't.
I guess the moderators are too busy locking stupid threads
-Sryth...
Old Sep 17, 2002 | 09:18 PM
-Sryth...
AGREE totally!!!!
Old Sep 17, 2002 | 10:29 PM
ThurzNite's Avatar
if you search for my username and the keyword "hydrolock" you'll find a heated debate about cai and bypass valve.
Jae
Apr 16, 2020 05:15 AM
mpbclutch33
Dec 26, 2015 11:11 AM
maxima297
Sep 30, 2015 03:32 PM
uttadms31
Sep 30, 2015 05:24 AM
Sep 27, 2015 08:37 AM
