Removing rear right spark plug - tips?
Old Sep 21, 2002 | 03:23 PM
bigd480's Avatar
I removed the bolt for that little plastic ring and I tried to remove the two bolts for that thing directly above it, per the instructions on VBMaxima's site...
I ended up getting the left one off and rounding off the other one... it's such a tight space, any ideas on how to remove it?
Old Sep 21, 2002 | 03:26 PM
95emeraldgxe's Avatar
use two extensions, that might help a little
Old Sep 21, 2002 | 03:36 PM
Jamsan's Avatar
Re: Removing rear right spark plug - tips?
ok you so you removed the bolt from that hting, and the other little thing, and that thing.... ...could be of more help if you were more descritive, or show some pictures and point out the things......are you talking about the screws on the coil packs, the brackets, what..?
Old Sep 21, 2002 | 03:45 PM
maxhead's Avatar
Using the right size socket and extensions helps a lot on the back plugs. You might want to have a magnet handy to get the one of the screws out once it's loose.
Old Sep 21, 2002 | 04:01 PM
Jamsan's Avatar
ya i dropped one of the screws into the top of the manifold....i was scared ****less...i had to go out side of the garage while they were getting it out, i couldnt bare to watch..
Old Sep 21, 2002 | 04:02 PM
Sprint's Avatar
have you tried my site yet?
http://64.252.156.63/tails/sparkplug.htm
Old Sep 21, 2002 | 05:12 PM
n2oMike's Avatar
One handy item is...
One handy item is a piece of flexible rubber hose... one that is the right size to slip over the end of the spark plug and hold it. The rubber hose works GREAT for extracting the old plug once it's loose, AND for re-installing the new one down into the hole. Large size vacuum hose or small fuel line is about the right size.
Good Luck!
Old Sep 21, 2002 | 07:31 PM
gepetto's Avatar
wow i had no trouble with this plug. what I did (i know this is stupid) is i actually hooked a big old torque wrench down in there so i had LOTS of leverage and no space cramps. thats it. try that if you like.
Old Sep 21, 2002 | 08:53 PM
iansw's Avatar
Re: Re: Removing rear right spark plug - tips?
Why not just use a spark plug bit from a ratchet set.....?
It holds onto the plug for you.
I dropped a coil screw down in my manifold 9 months ago. I couldn't see it anywhere. I just bought a new screw. 6 months ago I even installed my MEVI (took manifold off and put the ME Manifold on), and didn't see it anywhere.
Last week I took my manifold off to reseal it well because I've been having vacuum issues, and low and behold, THERE IT WAS!!! Stuck between the FPR and lower manifold.
IanS
Old Sep 21, 2002 | 09:51 PM
bigd480's Avatar
OK - update: i have replaced all plugs except rear right - that is the one where you have to remove three things (one bolt for the black plastic ring, which is easily removable, and two nuts on the thing next to it (EDIT: it's the EVAP), they are 12mm nuts with at least 1/2" of bolt thread coming up through them...
I have removed the bolt and one of the nuts but the one that is left (rightmost of the two 12mm bolts) but it seems badly stripped - it looks 7-sided... I've tried WD-40 twice, an open ended wrench (too little room to work), 12mm sockets (don't clear the bolt enough, just continue to damage the top of it), and adjustable wrenches/pliers (too large)...
Any ideas?
Old Sep 21, 2002 | 10:22 PM
iansw's Avatar
OK - update: i have replaced all plugs except rear right - that is the one where you have to remove three things (one bolt for the black plastic ring, which is easily removable, and two nuts on the thing next to it (sorry for the ambivalence), they are 12mm nuts with at least 1/2" of bolt thread coming up through them...
Any ideas?
Wha!?!?
On my car, it's just a wire snap-in harness and 2 8mm bolts that have phillips head tops......
Oooooh. You mean the EVAP!?!? Yes, you have to move that away....now I get it.
On mine, I have the MEVI, and moved my EVAP when I installed it..
IanS
Old Sep 22, 2002 | 12:31 AM
Sprint's Avatar
Any ideas?
in my write up i suggested a 12 mm deep socket..
Old Sep 22, 2002 | 07:15 AM
maxhead's Avatar
Any ideas?
Oh yeah, I forgot about the EVAP. Mine just came right off with the two bolts, that's probably why I forgot about it. To get a striped nut off, use vise grips. You'll never use that nut again, but it'll be off.
Just a thought, you might want to check the socket sizes. If you are using the right size, you shouldn't strip any of your bolts (make sure you use metric and not the closest standard equivalent. If you are using the right size, use the six (?) sided socket versus the 12 (?) sided socket. Look on the inside, one is pretty basic and one has a lot of edges on it. The 12 (?) sided on gets more grip but has more chance of stripping bolts. Anyway, get some vise grips, get it tight, take the bolt off, and buy a new bolt. Good luck.
Old Sep 22, 2002 | 12:35 PM
bigd480's Avatar
Everything on a Max is metric right? It's a 12mm nut and I used 3 different (6-sided) 12mm sockets but for some reason one was fine and one just got more and more damaged every time I tried... Will go get some vise grips - just hope it will fit
Old Sep 22, 2002 | 12:36 PM
Sprint's Avatar
if not.. take a dremmel to the nut and cut if off
Old Nov 1, 2005 | 10:07 PM
Split Level's Avatar
The Visionary...
Where did you buy the screw for the back far right coil package...I just cleaned mine and after 30 mins of trying to get the back ones off that stupid little screw decided to fall into my engine bay...I have no idea where it went so I might as well but a new screw...will this effect performance in any way with the coil pack being loose, even tho it is held in tight with the plastic stopper on the end of the pack?
Old Nov 1, 2005 | 11:10 PM
cefiro8701's Avatar
i jumped on top of my engine.
Old Nov 1, 2005 | 11:11 PM
gassian's Avatar
i just replaced all my spark plugs with platinums and on one of the rear plugs i saw oil around the plug on top....
what is that mean??
Old Nov 2, 2005 | 07:26 AM
iansw's Avatar
valve cover gasket usually.
Old Nov 2, 2005 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
3 yr old thread
Old Nov 2, 2005 | 10:08 AM
InsneDrmr's Avatar
Who goes back 3 years to find something like this? I mean I look back a few pages when Im looking for something, but definately not that far.
Old Nov 2, 2005 | 10:10 AM
NmexMAX's Avatar
dot dot dot ...
A else?
Old Nov 2, 2005 | 12:23 PM
bigd480's Avatar
wow, brought me out of retirement - i am still subscribed to this thread since I started it - was probably just a hit from search - which reminds me it's probably time to replace those plugs again...
Old Nov 2, 2005 | 10:20 PM
cefiro8701's Avatar
hahhahaa.....funniest thing ever.
Maxboy23
Aug 21, 2015 11:02 AM
BobMax
Aug 19, 2015 04:39 PM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
