Frankencar install pics...please help double-check :)
Old Sep 22, 2002 | 01:58 PM
Shoooter_j's Avatar
I'm still getting that 0807 ECU code, but it would be greatly appreciated if you guys could double-check my connections. I have faith in our fellow org. member costcowholesale for his install, but any other opinions would b great.
http://www.pbase.com/shoooter_j/intake
Thanx
Justin
Old Sep 22, 2002 | 03:14 PM
iregula's Avatar
looks ok but u have a 95-96 which has that air temp sensor i think
Old Sep 22, 2002 | 04:26 PM
Shoooter_j's Avatar
yep..that's the reason y.
Any more confirmations?
Old Sep 22, 2002 | 04:41 PM
maximamoose's Avatar
Re: Frankencar install pics...please help double-check :)
Thanx
Justin
just a suggestion, move the negative battery cable. don't let it sit on the filter!
Old Sep 22, 2002 | 05:24 PM
Shoooter_j's Avatar
great idea
will do asap!
Old Sep 22, 2002 | 05:36 PM
teejnut's Avatar
i stuck my air temp sensor in the actual filter on my jwt intake. worked fine for me. still waiting on frankencar midpipe.
Old Sep 22, 2002 | 05:41 PM
nadir_s's Avatar
vicodin ... gift of life
hmmm i didn't know about the air temp only being on the 95/96... i just ordered my frankencar, i can't wait to get it! I hope I don't run into that problem, i have a k&N filter that came w/ the car when i bought it so i'm guessing the air temp sensor has already been relocated... or do you have to do that w/ the midpipe only?
Old Sep 22, 2002 | 06:34 PM
gepetto's Avatar
I ziptied the sensor right behind the base of the cone. No code. It looks like one of your hoses may be loose (not sure). Check all that. Clean off your filter. Check your MAF. After that...
Old Sep 22, 2002 | 07:42 PM
BC_95GLE's Avatar
I actually got bored and drilled mine into the top of the filter so it is actually functional. Drilled the hole for the sensor and "Gooped" it on there with this special stuff that will hold no matter what you do to it stuff is nutz. Before that i had it laying on the tranny shift actuator, behind it actually. Brian
Old Sep 22, 2002 | 07:51 PM
JetBlackMax's Avatar
Heh, Looks to me like that Rubber piece you got with your Intake, is Right on the end of the throttle body. Heres what I did to fix that solution, This is probably why your getting that code. Get the Stock Black Filter box that your emoved, and take off the Flex part that used to be on the black box filter to the throttle body. Replace that little rubber ring with that. There fore you can have it all the way on the TB and it flexes to which ever way you put the whole intake.
There, that should help!
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
