Anyone know how to check if the spark plug coil is bad??
Old Oct 7, 2002 | 07:09 AM
Kevin's Avatar
I got the CEL code 0201, Ignition circuit signal. I tested the voltage of all the connecters that are next to the spark plug coils they are fine,
What I want to do next is check the actual spark plug coils,( the long plastic thing that goes in over the the plug itself)
How do I do this? do I have to check for voltage? Any help woudl be greatly appreciated.
EDIT: Does anyoen know what specific terminals to test resistance accross of? maybe someone could post the haynes manual instructions?
Kevin
Old Oct 7, 2002 | 07:12 AM
Sprint's Avatar
Bad Coil Pack Check
http://forums.maxima.org/search.php?...der=descending
DTC 0201
Old Oct 7, 2002 | 09:30 AM
Kevin's Avatar
Thanks!
Old Oct 14, 2002 | 11:54 AM
Kevin's Avatar
turns out all the cols packs are good. what nexT???
Old Oct 14, 2002 | 11:56 AM
Sprint's Avatar
did you swap coil packs and then reset the ecu to see if the code changes to another cylinder?
that would have been your first test..
if it doesn't change.. then i would say something is ither wrong with the plug in that location or the wiring is messed up..
Old Oct 14, 2002 | 12:02 PM
Kevin's Avatar
didn't try that, didn't even think of it either becuase the CEL only report 02 01, no other codes. Should I just randonmy swap coil packs aroujnd to see if other codes get reported??
Old Oct 14, 2002 | 12:10 PM
Sprint's Avatar
you know what.. after reading iwannabmw's post.. you should have had another code with it.. so reset it for now.. and see if the CEL comes back with a cylinder misfire code.. sorry for the run around Kevin
Old Oct 14, 2002 | 12:14 PM
Kevin's Avatar
Sprint,
I tried reseting the CEL a few times before and the same exact thing happens. On the next startup it the CEL doesn't come on, the startup following that, the CEL will stay off until I hit about 2k rpms. The car sometimes feels like the right side driveshaft is slipping or loose, sort of like a hesitation at low speed. sometimes the car shakes like hell like it's about to die, in reverse especially. but again no other codes besides 02 01. Thanks for your input.
Kevin
Slamrod
Sep 3, 2015 07:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
