wheels with 5 x 114.3 and 45mm offset. will they fit?
Old Oct 10, 2002 | 04:41 PM
optimus310's Avatar
Ok I hate posting stuff like this cuz everyone will be like " Use the search. Don't be lazy" I did used the search but I can't find the correct answer some of you say yes some say no. I am about to close this terrific deal on some 19x8 moda r6 wheels with the bolt pattern of 5 x 114.3 and the offset of 45mm. Will these wheels fit my 97 SE. This is one in a life time deal and I can't even search alot cuz I am at work. Please if some one knows let me know. Thanks.
Old Oct 10, 2002 | 05:25 PM
Sprint's Avatar
https://maxima.org/maxfaqs/sub_tires...#TiresWheels_5
Will 5 x 114 offset 18" x 8" rim fit on the Max?
Maximas support bolt pattern 5 x 114 and 18" X 8" rims. The offset should be in the 35-38mm range. Maybe you can fit less then 35mm but I'm not sure. Center bore was not mentioned but if the center bore is too small(smaller then 66.1 mm) the wheels will not fit onto your hubs. You might be able to get different hubcentric rings though.
Credit: Jeff92SE (answer) and SFMax20SE (question)
i think r6's fit no problem
Old Oct 10, 2002 | 05:50 PM
ivelweyz
He's asking about 19x8( why the hell, it's not an SUV new guy)...
Old Oct 10, 2002 | 05:59 PM
Sprint's Avatar
yeah i notice that after i posted.. i like 19's.. thats what i am getting if i get new rims
Old Oct 10, 2002 | 06:13 PM
Tifosi's Avatar
45mm offset is a bit too tucked in, IMO.
Tifosi
Old Oct 10, 2002 | 06:25 PM
Sprint's Avatar
Tifosi
your car looks like tony's.. its hot.. i love that sterling mist.. thats why i told my cousin to buy sterling mist..
Old Oct 10, 2002 | 06:28 PM
Tifosi's Avatar
Thanks man! Especially a compliment from Sprint!
Tifosi
Old Oct 10, 2002 | 09:17 PM
975spEEd's Avatar
Tifosi
45mm would actually be futher out than 35mm.
Old Oct 10, 2002 | 09:52 PM
I30tMikeD's Avatar
You've got that backwards. Higher offset more the wheel is inset.
Old Oct 11, 2002 | 06:11 AM
shaz's Avatar
Mine are 45mm offset too...havent put them on yet, debating on whether or not to get spacers
shaz
Old Oct 11, 2002 | 08:16 AM
Tifosi's Avatar
Yup, thanks I30tMikeD!
Tifosi
Old Oct 11, 2002 | 01:59 PM
theblue's Avatar
are they the correct size? NO
will they fit? MAYBE
I have 17 x 7.5 rims with a 45 offset and they fit and work well. They are not the ideal size but I was mostly looking for cheap rims to how wider tires at the time. Interestigly they will both stick in further and out further than stock rims so you don't really have to worry about them looking tucked. If you are going with a tire that will give you a larger overall sidewall than stock then they won't work because they will rub like crazy.
Old Oct 11, 2002 | 10:41 PM
I30tMikeD's Avatar
shaz
I have 40mm offset and am considering spacers. My rear my be a bit wider because it's the I30 though. It is just a little too tucked for me.
Old Oct 13, 2002 | 11:07 PM
1MAX2NV's Avatar
Isn't the stock 16s like 16X7 or maybe even 16X6. The reason 17X7.5 won't be looking tucked even with 45mm offset, it's because 5 mm is nothing in comparsion to the extra 1/2" in width.
Old Oct 14, 2002 | 07:43 AM
dashingMax's Avatar
Wheel Offset Calculator
Find out whether your rims will be tucked in or out by using this Wheel Offset Calculator
Stock rims on 4th gen SE is:
16x6.5 with 40mm offset
Cheers!
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
