PVC Value
Old Oct 14, 2002 | 11:54 AM
maxima168's Avatar
PVC Value
how can i tell if the value need replacemet. i got the code 1008. so should i replace it?
Old Oct 14, 2002 | 05:52 PM
DigitalTexan2u's Avatar
Simply remove it and look at it. If it's "caked" with oil...replace it...it's only like $3-$5.00
You can also shake it up and down...there's a ball bearing inside and it should move FREELY up and down...if it doesn't, then replace!
They're cheap...just replace it.
Old Oct 14, 2002 | 07:33 PM
maxima168's Avatar
thanks man.
i just replaced it last year. i brought it from autozone. it was hard to get it in there. there is a rubber peice i dont know if i was spouse to take that out because there is some oil around that and the value. it seems like it doesnt fit right.
Old Oct 15, 2002 | 08:22 AM
karguy's Avatar
Originally posted by maxima168
thanks man.
I had the same problem with PCV Valve I bought from parts store so I bought one from dealer and problem was solved.
Old Oct 15, 2002 | 10:06 AM
mzmtg's Avatar
Minister of Silly Walks
I cleaned mine out with TB cleaner...
Old Oct 15, 2002 | 10:09 AM
97MaximaSE's Avatar
i did the same but about a week later it seized up again but it has over 100k miles on it
Old Oct 15, 2002 | 10:48 AM
iansw's Avatar
If you use a panel popping tool to get to it, it's one hell of alot easier. I did it in 30 seconds, and no scratches on my fragile little hands either.
IanS
Old Oct 15, 2002 | 06:56 PM
97MaximaSE's Avatar
i just use needle nose pliers and pull up....only takes a sec
Golden Ice
Nov 22, 2003 07:15 PM
David89Max
May 29, 2003 10:02 PM
Sunrise
Jul 20, 2001 09:11 PM
mrloyd
Oct 25, 2000 12:08 AM
