Anyone Install an Air/Fuel Gauge ON There MAX?
Old Oct 15, 2002 | 07:35 AM
maxperformance's Avatar
Those air/fuel gauges look pretty nice when they bounce back and forth from rich to lean. I would love to get intake and then get the gauge. Anyone have this gauge, if so how did you install it on a max, if you dont mind me asking.
Old Oct 15, 2002 | 07:41 AM
ny96max's Avatar
yes about 4months ago.
Right in front of your valve cover thee should be two wire harness's. One of them has a red--white--blue wire in it. Tap that white wire and run the to your air/fuel gauge, DONE!
Ant
Old Oct 15, 2002 | 08:24 AM
Synki's Avatar
I had the gauge. This gauge is more for looks then purpose. I wouldn't even consider using this gauge to try and tune a car.
Old Oct 15, 2002 | 08:26 AM
WizzaMax's Avatar
I have one in my pillar pod...
Old Oct 15, 2002 | 09:01 AM
Jamsan's Avatar
as do i, but i wired it to my ECU o2 sensor return line, not the actual o2 sensor in the engine bay....
Old Oct 15, 2002 | 09:06 AM
redmaxpa007's Avatar
i SeE what you did therE
i tapped into the wire going to my ecu..(from the 02 sensor)
all wiring was done in cabin.. no wiring to the engine
Old Oct 15, 2002 | 09:07 AM
Jamsan's Avatar
great minds think alike
Old Oct 15, 2002 | 09:12 AM
Old Oct 15, 2002 | 11:23 AM
SLC I30t's Avatar
The WHITE wire? When I did this it just bounced back and forth over and over and over. I thought in the chiltons it said that the white
(postioned in the center) wire is the ground. and it was one of the other 2 wires.
EDIT---I've looked at the Service manual, and the white wire in my car (as stated above) is the center wire wich in the service manual is not the signal wire. The signal wire is diagramed that the #1 position wich is the left.
dank4us
34
Jun 10, 2024 03:45 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Stagnet04
Aug 30, 2015 07:30 AM
rbaker100
Aug 28, 2015 08:11 PM
acw
Aug 13, 2015 12:50 AM
