Tinted Brake Lights Gone Bad... Plez Help
Old Oct 18, 2002 | 11:02 PM
97maxinMA's Avatar
Whats up everybody, I tried to tint my brake lights today and royally messed up... they are totally black... I was told to coat it good the first time for a nice light tone.. boy were my sources wrong!!!! The lights are so black it looks like I have GTS covers on them... Any ideas on how to fix them.. maybe lighten them up a bit? I was thinking of using a really really fine steel wool but im not sure if that would hurt the finish... any input would be greatly apreciated...
Thanks In advance
Ryan.
Old Oct 18, 2002 | 11:09 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
If you used Tester's, you can spray another coat onto the taillight again, wait about 30 seconds or so and rub it off with paper towels. The tint should come off. Wipe it clean and start all over again. At least that's what I did long time ago. Just a suggestion; you don't have to take it.
Old Oct 18, 2002 | 11:29 PM
97maxinMA's Avatar
Thanks for the tip man ... I used a product called...Nite=Shades by VHT... ill try your idea though thanks from in input and prompt response....
Old Oct 18, 2002 | 11:35 PM
VeeQueue's Avatar
I've never used VHT before so I don't try that method!
Also for the Testor's method it can only be done on recently laid coats, not something you did 4 months ago.
I did a search on google and found this:
http://www.pjhbrands.com/vht/moto.htm
12. How do I remove VHT Nite Shades SP-999 Lens Tint?
Usually a little lacquer thinner on a clean lint free cloth will take it off. If the tint is more than 3 months old, it may be baked into the surface and normally will not come off.
Old Oct 19, 2002 | 05:53 AM
Kashoggio's Avatar
ahh Night shades it a bad thing to do, take some very very fine sand paper and start running
Old Oct 19, 2002 | 09:29 AM
SamMan23's Avatar
try some alcohol and see if that takes it off. If not you might want to try just a little bit of aceone or paint thinner. I'm not sure how those will react to plastic, so make sure it's just a little spot first(maybe use a q-tip).
Old Oct 19, 2002 | 10:33 AM
Dave B's Avatar
Not DAVEB the parts guy
Finger nail polish remover (ie acetone) is what you use. It will strip the paint, but won't harm the plastic (ie cloud it up).
Dave
Old Oct 19, 2002 | 12:05 PM
97maxinMA's Avatar
Thanks for the info guys, I'll try the thinner and let you know how it goes...
Thanks again for the quick responses!
Ryan
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
4doorGTR
Sep 11, 2015 04:09 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
