CDRW's in Bose
I know you can play cdr's in the bose system, and I am even getting away with the cheap green ones(won't work in a lot of stereos). Now my question is, can you use cdrw's? Most cd players won't let you, will the Bose in my '95se let me?
what they say the cdrw-s will only play in there brand player,,but the cdr-s play fine
Sure
I have 95 SE with Bose and play CD-R's all the time and also in a lot of other players. No problems. Only CD-R's though.
________
Peak Towers Condominium Pattaya
________
Re: Sure
heh
there is no car out there that can read a CD-RW unless your system consist of a Computer CD-ROM...CD-RW are basically for data and backing up no audio out put what so ever. CD-R is the way to go for quality!
Originally posted by maximumsport
heh
heh
Justin
CD-RW's won't work because most (all?) car stereo's look for a TOC (table of contents) at the beginning of the cd. The TOC only get's written when the CD is finalized, so that's why CD-R's have them and CD-RW's do not. If you're stuck with the CD-RW's and want to use them, most burning software will have an option to "finalize the disk" and that should put the TOC on it but at the same time you won't be able to re-write it.
Chris
Chris
heh
heh
The TOC isn't the issue of why certain CD players cannot read CD-RW discs, it's the reflective properties of the disc's pigment. It has a lower rate of reflection and requires a laser pickup with a far more sensitivity than most standard CD players. One can write a perfect redbook standard CD-Audio disc on a CD-RW disc, so the content of the disc is not an issue.
As for CD-RWs in the car, I have found that a number of aftermarket head units will play them with no problems, whatsoever. Pioneer, Aiwa, and quite a few of the newer Alpines go without a hitch, even if the disc has only a closed session rather than complete finalization. As for the Bose playing RWs, I highly doubt it. My Bose will occasionally choke on the cheapest of the cheap CDRs (generally the darker greens), so I cannot imagine it sucessfully reading the dull pigments of an RW disc.
to clean up this issue for once and all... some player wll take CD-RW and some won't most will require you to have a TOC for them to work. Its really random until somebody tries it, and even then it may be down to te way they burn it and what they burn it on. Nobody will ever win the argument about if they will or will not work. My opinion is that burnt correctly they will work perfectly.
I have the Bose system in my 99 and it won't play RW's either. My only suggestion is to take your favorite cd's that are on RW's and just copy them to a regular cd-R disc. I had to do that a couple of times and they work just fine now.
So then the final answer is no, CD-RWs will not work in the Bose CD player in the Max, but a properly formatted CD-R will. It's actually recommended by CD-RW manufactuers that ANY data that is to be shared between components or other computers be put on CD-R, because the reading/writing/TOC algorithm isn't/wasn't the same for all ReWritables.
Ya Ha...
heh
heh
Re: Ya Ha...
Originally posted by THosie
No... Aiwa makes an aftermarket deck that reads MP3's on CDRW and CDRS as well as audio CDR's and CDRW's... http://www.crutchfield.com/cgi-bin/S...CDCMP3&o=M&a=0
heh
heh
