Had my thermostat replaced today...
Old Dec 26, 2000 | 04:22 PM
Micah95GLE's Avatar
My Nissan tech charged $85 for the job, including a radiator flush-and-fill (which I needed anyway). No more staring at the temp gauge now!
Old Dec 26, 2000 | 05:55 PM
Briguy1971's Avatar
I had the same thermostat problem with my (just purchased) 95 Maxima. It didn't take me long to replace it thanks to this forum!!! (Thanks guys!!!)
Anyway - I wanted to update this so people would know exactly how to do it.
All I needed was a 10mm socket, a socket extension and a phillips head screwdriver. You don't need to remove anything to get to the thermostat. It's located on the passenger side of the engine - just follow the hose back from the radiator. Got the 'stat from the dealer ($12 bucks). I used the existing gasket cuz it was fine and didn't drain the coolant. I didn't even have to add any anti-freeze. Easy job
Brian
Old Dec 26, 2000 | 06:19 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Really
My car seems to keep a funny temp too. I was thinking about changing it. It's above the coolant line so none escape?? If so i might do it this week.
________
AROMED VAPORIZER 4.0 REVIEW
Old Dec 26, 2000 | 07:30 PM
mo'max's Avatar
Replaced thermostats
Micha /Briguy -
I'd be curious to know what milage you have on your rides. Also, is this your first replacement? I'm on my 3rd thermostat (110K miles 95SE).
Briguy - did you happen to notice what was wrong with yours?
Old Dec 26, 2000 | 08:44 PM
justmax's Avatar
Briguy?
Hey thanks for the info, very helpful, but...
ummm... are those Chevrolet Cavalier *PLASTIC* hub caps on your Max? Cuz that's what they look like.
Please say I'm wrong. Maybe it's just the angle of the picture. Yeah, that's it. NO one would ever THINK of doing something like that, right?
(uneasy pause)
No offense, man.
Justin
Old Dec 27, 2000 | 03:54 AM
Micah95GLE's Avatar
I have 105K miles. I have the old thermostat in front of me. The plastic part that slides the valve up and down around a brass-colored shaft apparently has been warped out of shape over time, so there are scratch marks in certain places. This is probably where the thermostat was sticking open. Then, if I idled the car for a few minutes, the heat soak in the engine bay would cause the plastic ring to expand and then it would pop back into place and work normally. No more of that, though.
Old Dec 27, 2000 | 09:47 AM
Briguy1971's Avatar
dmbmaxima88 - I was real careful to keep the hose as high as I could. Look at the puddle in my pic - thats all that leaked out.
mo'max - mine has 77.5k on it. Only had it a week. Problem with mine was the car never would heat up. Temp gauge never moved and the heater was a waste when it was freezing.
justmax - No you didn't! Yes - those are plastic hub caps on my car. I just bought it about a week ago so it's stock from bumper to bumper. Only thing I've done is the 'stat and replaced the stereo. Gimme time man.
Brian
[Edited by Briguy1971 on 12-27-2000 at 11:55 AM]
PH98I30
29
Feb 10, 2025 12:03 PM
cruce91
Sep 20, 2015 10:23 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
