Cruise Control Problem?
Old Nov 7, 2002 | 04:54 PM
MaximaMoJo's Avatar
Ok, this is just weird, when I set my cruise and just crusing everything is fine but, when I use my turn signal the cruise shuts off. I was installing some stereo equipment last night and took the cables off of the battery which, I thought would reset the ECU and solve the problem. This did not solve the problem. It really sucks because I always use my signal to change lanes and the cruise shuts off. I have a 99 5spd if that helps. Any insights would help!
Old Nov 7, 2002 | 06:01 PM
MaximaMoJo's Avatar
bump
Old Nov 8, 2002 | 05:10 AM
arrow96's Avatar
Originally posted by MaximaMoJo
bump
I had this problem on a 97 Pontiac Grand Prix GTP. The cruise would kick out when the intermitent wipers would cycle. It turned out to be a bad ground. I would find and clean all the grounds from battery through those on the engine. There are several. Do a search for ground or grounding. There is a kit that oversizes all the grounds and is suppose to increase HP. There are some pics on these posts that show where all the grounds are because some folks are making their own heavy grounds. I've been wanting to do this but no time.... Hope this helps....
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
slowlifer
Sep 8, 2015 05:53 AM
