Code From PL Cold Air
Old Nov 13, 2002 | 05:50 AM
maxperformance's Avatar
anyone get a ecu code after installing a cold air intake, my over drive light blinks like 17 time when i start my car after i got the cold air. What the hell does it mean, i dont notice any difference in anything.
Old Nov 13, 2002 | 06:18 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: Code From PL Cold Air
Transmission ECU O/D Light Diagnostic Procedure when Overdrive light blinks or is blinking (98 & 99 Models Only):
http://forums.maxima.org/showthread....threadid=63295
Get a Haynes manual or an FSM for the 95 to 97 procedure, as it is slightly different. However, the actual blinking sequence and code meanings are the same.
It is on page 7B-3 of the Haynes manual. This procedure can easily be confusing, and except for the Vehicle Speed Sensor or Throttle Position Sensor (TPS), all other repairs should only be done by a qualified transmission shop. The VSS and the TPS mentioned above should throw an ECU code. If they don't, and only the O/D light blinks, then you're in trouble.
KabirUTA13
19
Oct 17, 2015 02:15 AM
jchronis2552
Sep 21, 2015 05:52 AM
pears
Sep 18, 2015 05:25 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
