Squeeking noise from left front, any ideas?
Old Nov 16, 2002 | 01:00 PM
KINGMAX's Avatar
I have had this intermitant squeeking coming from my left front wheel, and I can't figure out what it is. The squeeking seems like it only happens when I turn the wheel(more often when I make a right turn). I tried to search a few things. I thought it was my wheel bearing but it seems from what I have read that this is more of a humming noise. All I can think of is my rotor might be warped. I have crappy brake pads on the front(they make the same noise when I brake) they got very hot and fade very quickly under hard braking which I think might have caused a warped rotor, and my squeeky brake pads are rubbing against the rotor more than they should. Any help is greatly appreciated.
Old Nov 16, 2002 | 01:07 PM
Nealoc187's Avatar
SLOW
Do you have aftermarket suspension? Sounds like a strut mount bearing that is on its way out but not completely gone yet. I get weird creaks and squeaks when mine are torn up a little.
Old Nov 16, 2002 | 01:09 PM
KINGMAX's Avatar
No, my suspension is stock. Thanks for the idea, I am going to run a search on that.
Old Nov 16, 2002 | 01:25 PM
KINGMAX's Avatar
When I did the search it seems like people are getting more of a clunking noise from the strut mount bearings than the high pitch squeel I am getting.
Old Nov 17, 2002 | 10:50 AM
XxJ822xX's Avatar
Re: Squeeking noise from left front, any ideas?
it might be your CV boot/joint
Old Nov 17, 2002 | 11:19 AM
mohfo's Avatar
front sway bar bushing?
Old Nov 17, 2002 | 01:02 PM
n2oMike's Avatar
Go here and click on 'interesting fixes', then click on 'turning noise fix'.
http://www.motorvate.ca/
What happens, is that when the wheel is turned, the spring has to be free to rotate. For this to happen, there is a small bearing at the top of the strut. If the bearing freezes up and stops turning, the coil spring winds up, then turns all at once making a 'thunk' sound. It will usually happen at slow speed when the wheel is turned and you hit a small bump.
Good Luck!
Well, on second thought, what you are describing seems more like the brakes.
If you don't install new rotors or have yours turned when a brake job is done, or don't use silicone on the backs of the pads, the brakes can squeak just driving down the road. They will also do this regardless if they are very worn. The factory installs little 'squeakers' on the pads to warn when they are getting worn out. Go to autozone and get some new pads and $22 rotors.
Good Luck!
Hondarydr
Dec 30, 2024 06:15 PM
boomerbrian
Nov 8, 2015 05:10 PM
bc992164
Aug 26, 2015 12:19 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jholley
Aug 11, 2015 09:38 AM
