Need help with lug nut...
Old Nov 16, 2002 | 05:36 PM
hacim105's Avatar
I was changing my oil and when I was putting my rim back on I asked my friend to put the lug nuts on the car so I could tighten them. Well she has to be dumb and she didn't screw the lug nuts on she just pushed them on so they stuck there. Anyway I have an air compressor tool and i started to screw the bolt on. Well the lug nut stripped and the bolt stripped a little also. I'm going to try and get a new lug nut tomorrow and hope it screws on. Has anyone had this happen? I don't want to spend gobbs of money to get this fixed but I might just have to, which will suck. If you can help thanks.
Old Nov 16, 2002 | 05:56 PM
metallic97gxe's Avatar
Master Will
you will need to get a new stud put int...it is not that bad to have 4 out of 5 lugs on..but get another stud put in...
Old Nov 16, 2002 | 06:19 PM
gepetto's Avatar
Man how hard did she push
Women...
Old Nov 16, 2002 | 08:06 PM
SamMan23's Avatar
Re: Need help with lug nut...
It happened to me when I decided to tighten all my lug nuts on the ground as opposed to in the air and then torque on the ground. I had to replace the bolt. Just get another nut and bolt and put it on. You have to hammer the old bolt out.
Old Nov 17, 2002 | 10:47 AM
hacim105's Avatar
Re: Re: Need help with lug nut...
Is this difficult? How do you do it? Where should I go to find a bolt? If you can help me I'd appreciate it I need to have this done by today if possible.
Old Nov 17, 2002 | 01:54 PM
hacim105's Avatar
Nevermind, I was able to change the bolt and everything. Thanks for your help. It is very much appreciated.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
dcam0326
Sep 26, 2015 05:20 AM
_DRU_
May 4, 2001 09:32 PM
Cumalot
Nov 13, 2000 06:58 AM
