rotating tires....
Old Nov 23, 2002 | 04:18 AM
Jamsan's Avatar
rotating tires....
i plan on rotating my tires today, but im not sure exactly how im going to support one end of the car while i take off the other wheels....i only have 1 jack, so what do you recommend i use to hold up the other end of the car? and where should i place it? same spot as the place for the jack? thx
Old Nov 23, 2002 | 04:53 AM
karguy's Avatar
Re: rotating tires....
Get a pair of good jack stands! Safest way to go. I use an 8 inch
piece of 2x4 on top of jack stand. I put it right next to where the jack is. Works fine. I use a piece of 2x4 to avoid damage to car under carriage. Been doing this for years.
Old Nov 23, 2002 | 09:48 PM
White96MaxSE's Avatar
Re: Re: rotating tires....
I'm with you on this, but I would use 4 jackstands. Put the jack under the rear beam and jack up the rear and place two jackstands there.
Next, Move the jack to the front jackpoint and after getting it up in the air place a jackstand there. Repeat on the other side.
Now, you have the whole car in the air to rotate tires.
Always jack the rear up first so that you don't push the weight of the car down on the front jackstands. This can lead to crunching the undercarriage!
Just a quick hint.
96WhiteMaxSE
Old Nov 24, 2002 | 07:44 AM
99maxi's Avatar
remember to unscrew the lugs a little before u raise the car.. it will be easy with the car on the ground.
Old Nov 24, 2002 | 09:17 AM
SuDZ's Avatar
Which way you plan on rotating them?
SuDZ
Old Nov 24, 2002 | 09:24 AM
fast97maxse's Avatar
I rotate my tires every time I drive
Old Nov 24, 2002 | 09:37 AM
pondo's Avatar
You can do it with one jack and a spare tire, but it's a lot of extra work. I did it once, but now I have jack stands ($20 or less at your local parts store, just buy 'em).
Here's the plan:
Jack up one tire, remove, replace with spare tire. Lower car.
Go to next wheel in rotation, remove, replace with previous full-size tire.
Go back to the spare tire-ed corner, remove spare, replace with full-size.
Repeat for the next two tires.
All told, that's 6 jack operations, took me about 30-45 minutes working alone, using the emergency jack.
Later,
Josh
Old Nov 24, 2002 | 09:48 AM
RI-Max's Avatar
i rotate my wheels ever other oil change but i have access to a lift. but i would buy some jack stands if i was u .
MatthewsMaxima
Sep 11, 2015 03:21 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
jfl330
Sep 4, 2015 01:44 PM
gizzsdad
Aug 19, 2015 01:01 PM
