Starting woes - took 5 tries to get my max finally started
Old Dec 27, 2002 | 12:02 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
earlier today I started my max as normal, would run for about 2 seconds, cut out and then stall, then waited about 20 seconds to try again, same thing, repeated this process for about 3 to 4 times before it finally started and kept running. I have near 85.5K on the odometer and recently replaced the alternator c/o the recall, what can be causing this?
Btw this happens when the car is "cold" started
Old Dec 27, 2002 | 12:48 PM
HarrisH's Avatar
Might need to clean your throttle body.
Old Dec 27, 2002 | 01:52 PM
MDubya
mine was moshed like that too. check that ecu. mine threw back a engine coolant temp sensor (bc the car didnt know it wasnt warmed up in the morning),,
But then it kept doin it till i just replace the engine Knock Sensor. pricey.. mdub,.
Old Dec 27, 2002 | 03:31 PM
Rogo02SE's Avatar
I had the same problem couple of days ago.
I'm not sure but I think that my problem was water in the fuel system.
I put drygas in the tank filled it up and so far everything works fine.
Old Dec 28, 2002 | 11:30 AM
fuel pump?
My guess is that the fuel pump is going bad, causing my max not to start becuz this happened w/ my mom's '95 Blazer, could this be the cause? If so how much are fuel pumps for Max's?
Old Dec 30, 2002 | 11:48 AM
update
starting is getting even worse, now its taking 10 tries to get my max sstarted? When the car is warmed up, however, it starts right off the bat. Any other symptoms besides a dirty TB that are causing this?
02PearlSE
Oct 7, 2015 02:12 AM
conansriver
Sep 3, 2015 06:38 AM
305head
Aug 26, 2015 09:03 PM
maxinout93
Aug 16, 2015 07:25 PM
Balkins
Aug 12, 2015 06:39 AM
