What is the best air filter for PL Cold Air Intake?
Old Jan 6, 2003 | 05:14 PM
maxperformance's Avatar
I know it comes with the :monster flow filter", it seems to be alright-and the people from Place Racing said it's the best when I called them up. But I dont really like "foam" filters...should i get K&N? Help me out guys. What do you suggest huh?
Old Jan 6, 2003 | 05:36 PM
Jime's Avatar
Re: What is the best air filter for PL Cold Air Intake?
You are asking a question that will give a multitude of answers that could all be right.
Its like asking whats the best brand of nitrous, oil, tranny fluid, etc
Everyone has their own opinion and when you get them all you still won't be any further ahead than you are now.
Old Jan 6, 2003 | 05:50 PM
maximaah's Avatar
Apex'i apparently has been shown to have better flow characteristics to the traditional cone of the K&N. Either will work, just don't get one with foam that will deteriorate and get sucked into the engine.
Old Jan 6, 2003 | 07:10 PM
Re: Re: What is the best air filter for PL Cold Air Intake?
Well..Thats not true, I just went to the Apexi web site and they only make filters for the 240sx, and the 300zx! Im pretty upset- it sounded like a really good idea! But at the end of the list it said "Universal Replacement Filter (Filter Only) 80mm." So what does that mean? Is 80" 3 inches ( i dont think so ) because I know the filter has'to 3 inches. I want apex so what do i do.
Old Jan 6, 2003 | 07:19 PM
ny96max's Avatar
K&N part # ru2820
thats what the original PR CAI came equiped with
Ant
Old Jan 6, 2003 | 07:37 PM
To ny96max---
personally do you think the K&N is better than the foam monster flow filter?
Old Jan 7, 2003 | 12:07 AM
buss95max's Avatar
imma try the apexi filter when i have the money to buy one. ive gone thru 2 k&ns already..cleaning them doesnt really do anything(visually)
Old Jan 7, 2003 | 07:00 AM
1MAX2NV's Avatar
Since K&N is made of cotton, I soak it in a bucket with laundry detergent. It gets pretty clean.
Old Jan 7, 2003 | 07:27 AM
Jamsan's Avatar
My K+N looks brand new after I clean it out...I use the cleaner kit, and re-oiling kit after, and it just looks marvelous...However, with my engine bay being so dirty, my filter gets filthy ever 2-3k miles
Old Jan 7, 2003 | 08:12 AM
n2oMike's Avatar
You might try one of those K&N Precleaners that slips over the filter to trap the big stuff... either that, or cut the leg off an old pair of panty hose and tie it around the filter. If it is installed behind the foglight hole (with no foglight) a shield would help protect it from direct 'hits'.
Good Luck!
Old Jan 7, 2003 | 09:12 AM
breaux124's Avatar
I've been happy with my K&N. I clean it every 20K-30K miles and it still looks great.
Old Jan 7, 2003 | 12:40 PM
n2oMike's Avatar
A cheaper alternative might be the BOMZ unit with a new K&N filter. I don't think I'd trust any of the cheapo filters out there on my maxima.
I'd still add a pre-cleaner/pantyhose and an airshield of the foglight isn't there.
Good Luck!
Old Jan 7, 2003 | 12:52 PM
slavik'sMAX's Avatar
I am very happy with K&N as well.......I do have to clean it every 15,000 miles
Old Jan 7, 2003 | 05:56 PM
GUYS PLEASE, BACK TO THE QUESTION
What do you guys think is better keeping the monster flow ""foam" filter or getting the K&N Filter. Agiain i went to the APEX website and they dont make filters for maximas, just for the nissan 240sx, and 300zx. Also how much does a K&M cone filter cost?
Old Jan 7, 2003 | 07:14 PM
ny96max's Avatar
from what i hear, the monster flo's eventrually break down and cause the motor to suk in small particles of foam, i dunno if thats tru or not, buts its what ive been told
Ant
Old Jan 7, 2003 | 07:15 PM
Greg's2kGLE's Avatar
I am sure Apex'i makes universal filters. Ask Steve at Frankencar what he uses.
Also, check out this website for filter comparisons. Apex'i wins hands down.
http://www.mkiv.com/techarticles/filters_test/2/
Old Jan 7, 2003 | 07:19 PM
DTR Maxima's Avatar
know apexi makes filters because quite a few members have them. do you all think i should get rid of my monster flow and throw on a k&n?? and performance gain?? does the k&n sound better?? is it worth it?
Old Jan 7, 2003 | 07:50 PM
exhip95's Avatar
Re: GUYS PLEASE, BACK TO THE QUESTION
The universal filter at 80mm is 3.149inches (25.4mm per inch). it is just barely larger in diameter so it will probably work fine.
K&N cone is about $40.00
Old Jan 8, 2003 | 06:47 AM
n2oMike's Avatar
As for the Apexi...
The test says the Apexi is a dry type (no oil), never needs cleaned, and lasts a lifetime.
How's that?
I guess you could make the same claim with the stock paper filter... It will surely need cleaned or replaced from time to time, and since it says you don't clean it, you buy replacements.
How much do these things cost? I like the idea of these filters not needing oil so there won't be any accumulation on the MAF, but I don't want to get in the habbit of replacing $expensive$ filters every 10k miles.
Let's see, a Bomz setup (made from aluminum by the way) for around $65 shipped, plus a top of the line filter puts a person in charge with a top notch CAI for around $100!
Thanks!
Old Jan 8, 2003 | 07:02 AM
BEJAY1's Avatar
Conecarver
K&N vs MF dyno again
http://forums.maxima.org/showthread.php?threadid=132358&highlight=dyno
I think the question shouldn't be what the best filter but rather what the best intake is for both low and high RPMS.
I would be curious about the Apexi performance though.
Old Jan 9, 2003 | 06:41 AM
Anachronism's Avatar
Originally posted by ny96max
K&N part # ru2820
Ant
Does anyone know what the biggest K&N that will fit comfortably in the fenderwell is? Anyone know a good place to get K&N filters cheap? And I second the suggestion about ~$65 Bomz CAI plus ~$40 K&N.
zzznightmarezz
Sep 21, 2015 06:32 PM
Keyno McMike
Sep 21, 2015 07:18 AM
pears
Sep 18, 2015 05:25 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
