problem with remote programming
Old Jan 10, 2003 | 11:43 AM
LeonBlackMax's Avatar
Ok when i insert my key in and out the hazard lights do not flash!
Old Jan 10, 2003 | 11:50 AM
njmaxseltd's Avatar
Get in the car, lock the doors from inside the car with the power lock switch on the door. Insert the key more then 10X in less then one millisecond. OK so maybe thats a bit to fast, but you get the idea.
Old Jan 10, 2003 | 12:04 PM
I did that and they will not flash.
Old Jan 10, 2003 | 12:36 PM
MrEous's Avatar
^ Jeff™
Are you sure you have the Security & Comfort package? Just checking. I made that mistake. (flame on)lol
Old Jan 10, 2003 | 01:20 PM
yes my alarm goes off on me all the time.
Old Jan 10, 2003 | 04:09 PM
ok guys i hope one of you can help me. Well when i put my key on the acc position and hold the lock button like in the instructions the hazard lamps blink twice. So i know its getting the signal. But what i think is that it already has the maximum of 4 ID codes in memory so its not accepting the one i'm trying to program. Is there any other way to delete these codes?
Old Jan 10, 2003 | 04:16 PM
hacim105's Avatar
As soon as you do what you just did you reset all codes. After you hit the lock button and the hazards come on, then pull the key out of the ignition, unlock the door MANUALLY and open it. Then shut it and your keyless entry should work.
Old Jan 10, 2003 | 04:45 PM
i thought when you slide the key in and out of the ignition is when you reset the codes? Well when i do that the hazards never flash.
Old Jan 10, 2003 | 06:14 PM
njmaxseltd's Avatar
Your not doing this part correctly then. Like hacim105 said you just deleted all your codes. Now you just have to get that key in and out thing under control. Read my previous post.
Old Jan 10, 2003 | 06:25 PM
ok i get in the car, lock all the doors and put the key in and out about 8 times fast. The lights will not flash, i've tried numerous times.
Old Jan 10, 2003 | 08:07 PM
hacim105's Avatar
Make sure the key goes in and out all the way. You have to do it under 10 seconds like 5-8 times.
gtr_rider's Avatar
192.168.1.1
you have to continue doing it until the lights flash, then put the key to ACC then press the lock button. then take key out, and open the door
Old Jan 10, 2003 | 08:21 PM
i keep going and the lights refuse to flash.
Old Jan 11, 2003 | 12:42 AM
NoMoreAlty's Avatar
open the door by unlocking it bt the handle or by the panel that unlocks all the doors.? im having problems too. the hazrds flash but when i hit the lock button after i put the key to acc it doesnt flash. i bought a new battery . the only thing is that ther remote is from a 96 i30
Old Jan 11, 2003 | 03:01 AM
ok dude you have found the solution, k , listen um k, uh if we both switc problems we will be ok, fuc####, shi@@@@@, ok i been tryin and dude u doin what i can't and i'm doin what u cant . HELPPP U maxima org ppl.
Old Jan 11, 2003 | 09:37 PM
bizz's Avatar
listen, get in car, close door, lock doors, insert the key six times into the ignition, thats IN and tottally out and back in .. do it slowly.. with in 10 seconds.. 10 seconds is a lot damn it so not need to rush, the hazord lights will flash twice to confirm the old key fob list was earsed.. now press any key on the remote control and now un lock the door and open to finish the programing!
Old Jan 12, 2003 | 01:01 AM
lights do not flash , i repeat lights do not flash.
Old Jan 13, 2003 | 09:29 AM
genepool's Avatar
Hmmm.....I recently programmed a remote 2 weeks and ago and when I inserted and re-inserted the key, it didn't work. The next time, I didn't completely pull the key out. I pulled most of it out and reinserted it well over 10 times until the hazards flash. That might help....it can be very frustration though.
Old Jan 13, 2003 | 12:19 PM
ok it works now, the hazards still never flashed though with the key, i just pressed unlock while inside the car and heard a click and it started working
ah well it works so thats all that matter i guess. thanks for the help though.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
