need help: lights/fuses blowin out after installed altezza
Old Jan 12, 2003 | 02:42 AM
happyricefob's Avatar
V^___^V
so today i put in my $41 carbon fiber altezza tails from ebay, it looked awesome when it completed... i tested both lights on and off, steppin on the brake, and the directional signals... 2nite i went ballin with my friends who was drivin behind me...he told me my tails was PITCH BLACK! but when i step on my brake the lights are out... i suspected it's probably blown fuse so i checked it out... for some odd reason my corner lights blew out too! so jus imagine driving home after ballin, 1 am in the morning with my head light on the whole time on the freeway...
i'm gonna replace my fuse for both my tail lights and corner lights... also the the 2 bulbs for the tail's reverse light... i actually replaced one bulb already cuz it blew out... quickly after awhile another one blew out too... i picked up the same bulb for 75 cents and tat one was blewed out too..
SO THIS IS VERY FRUSTRATING... HELP MEEEEEEEEEE!!!!
Old Jan 12, 2003 | 07:25 AM
I30tMikeD's Avatar
All that Ballin can be hard on fuses.
Old Jan 12, 2003 | 12:54 PM
V^___^V
so should i switch to higher fuses votage? for the tails they are 7.5A, so u think i should use 10A?
Old Jan 12, 2003 | 01:00 PM
96max5sp's Avatar
Yes switch to 10s. I had the same exact problem and switched to 10s, problem solved.
good luck
Old Jan 12, 2003 | 01:47 PM
d_warner's Avatar
Old Timer
As for the bulbs blowing, DON'T Touch the bulb. If you do, clean it thoroughly. The bulbs heat and expand so fast that if there is oil from your fingers on the bulbs, that small portion of the bulb will heat and expand at a much slower rate causing the bulb to blow.
David
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
