I got a electrical question, need help
Old Jan 7, 2001 | 04:41 PM
Cumalot's Avatar
I need help trying to install a Varad EL scanner. There are 3 wires that I need to deal with. A red wire that goes to the + battery, a black wire that goes to ground, and a yellow wire that goes to the ignition; that way the system is armed when the ignition is off/key is removed. I understand how to connect the red and black wire. Just not too sure about the yellow wire. The diagram show that the yellow wire goes to the fuse box(one just above your left knee.) So, how am I suppose to go about this? Which fuse in the fuse box do I have to connect the yellow wire to? And when I connect the wire to the fuse, do I just connect it directly? i.e.(Just take the wire, stick the wire into where the fuse would go, and then plug the fuse in there also?) I am just not too sure. Thanks for any help.
Old Jan 7, 2001 | 05:16 PM
seven's Avatar
just take the wire and wrap it around the
fuse and then put the fuse back in. see if you can find another way to connect the that yellow wire b/c i never did safe with a wire jammed into the fusebox.
Old Jan 7, 2001 | 06:00 PM
Cumalot's Avatar
Ok, now which fuse though? Which specific fuse should I connect the wire to? That's the part I can't figure out, or just not too sure.
Old Jan 7, 2001 | 06:29 PM
seven's Avatar
another alternative is the yellow wire to the
radio. this wire supplies constant power so that your radio remembers stuff you programmed in like radio stations, etc. if you have an aftermarket radio, its the yellow wire on the wiring harness. if not lets see, try the hazard lamp fuse. i just went to my car and those lights work w/o the keys.
Old Jan 7, 2001 | 07:11 PM
Cumalot's Avatar
Thanks seven! I'll try it out tomorrow. I hope it will work.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
