Dyno'd the Max today!
Old Feb 8, 2003 | 11:33 AM
1SikMax's Avatar
Here are the results.
Run #1 : POWER=151.9 TORQUE=174.2
Run #2 POWER=152.7 TORQUE=176.9
I just have a K&n drop in filter running 92 oct.
I will post the pics and chart as soon as I can get ahold of a scanner.
Old Feb 8, 2003 | 12:02 PM
redmaxpa007's Avatar
i SeE what you did therE
Re: Dyno'd the Max today!
i am assuming you have an auto.. those numbers are about right..
Old Feb 8, 2003 | 01:09 PM
1SikMax's Avatar
Re: Re: Dyno'd the Max today!
ACTUALLY, no I have a 5-speed. I don't think the numbers would change with the tranny diff. would they?
Old Feb 8, 2003 | 01:11 PM
Re: Re: Re: Dyno'd the Max today!
most 5 spd peeps see almost 160. hp
but 150-160 would be normal..
Old Feb 8, 2003 | 01:19 PM
1SikMax's Avatar
Re: Re: Re: Re: Dyno'd the Max today!
Awesome! Thank you. Had me worried there for a sec. My dyno is real choppy. I was thinking maybe I had a bad coil pack cause I had the CE light come on afew times about a month ago and it was a 0201. But then I disconnected it and reconnected it then reset the ECU and it's been gone since then. You'll see the dyno when I get it up, it is reeeaaallllyyyyy choppy.
I wish I was pushing numbers like this 240sx with a Silvia motor swap in it. POWER=220 TORQUE=210
Old Feb 8, 2003 | 01:34 PM
CaLSoNiC
Re: Re: Re: Re: Re: Dyno'd the Max today!
Get Turbo on the VQ30 youll blow that 220/210 outta the water :P
You cant really compare a turbo engine to a NA engine, even though that 240SX had a 4-cyl SR20DET.
Old Feb 8, 2003 | 07:37 PM
Nealoc187's Avatar
SLOW
Those numbers are a bit low for a 5spd, check that coilpack. You should be right around 160hp and 175tq if everything's working right on a dynojet.
Old Feb 9, 2003 | 03:46 AM
that is what i thought..
150 for autos and 160 for 5 spds.. that is about the correct??? correct??
Old Feb 9, 2003 | 05:23 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Hmmm...you have a 99.
Cali spec or federal spec?
If you're Cali spec you'll have these four wires at the front of the engine bay from the 4 o2 sensors. Fed spec you'll have 2 or 3 (I forget)
Old Feb 9, 2003 | 05:25 AM
cali spec is 4 02 sensors
fed spec is 2 o2 sensors...
Old Feb 9, 2003 | 08:48 AM
Lime's Avatar
hmmm...well have you checked your ECU lately? Maybe the KS is going bad? The only way you can tell is to check the ECU...if it's just the KS then you won't pop a code.
Old Feb 9, 2003 | 09:07 AM
Nismo87SE's Avatar
CAn you tell us what rpm the power and torque peaks occur at? Also how much power/torque does the car have at 4500 and 6000rpm?
Old Feb 9, 2003 | 09:48 AM
1SikMax's Avatar
I am going to get the Dyno Chart scanned hopefully tomorrow and you can see what it's doing. I am thinking it is a Cali. spec engine if IM looking at it right. It has just what the picture shows the four wires infront. Does that affect hp also?
captchaos
Mar 15, 2016 12:18 PM
wingnut2006
Sep 19, 2015 06:13 AM
ik95
Sep 16, 2015 08:11 PM
MaxLife17
Sep 8, 2015 02:36 PM
