Max wont start
Old Feb 28, 2003 | 04:04 PM
jaymode's Avatar
Max wont start
Alright my sister's boyfriends maxima will not start. He says that it cranks but will not turn over. It is a 98. What should I look for as being the problem? It is about 35 degrees out so i do not think the gas is frozen. It has about 60k miles on it. Also it has been parked on a hill and does have gas in it. He wants me to take a look at it, but i really am not too sure what is wrong, but I have not looked at it yet just from what he says.
Old Feb 28, 2003 | 05:53 PM
andreyyy's Avatar
it can be battery or fuel pump fuse or starter.
Old Feb 28, 2003 | 05:58 PM
hacim105's Avatar
Probably not the battery. If it's turning over there is something with not enough fuel or not enough spark. Like he said it may be the starter or somthing to do with the fuel pump.
Old Feb 28, 2003 | 06:51 PM
happyricefob's Avatar
V^___^V
try to jump it
Old Feb 28, 2003 | 09:16 PM
|\|issan|\/|ax's Avatar
Check coolant temp. sensor. It is the "choke" for the car.
Old Mar 1, 2003 | 05:34 AM
jaymode's Avatar
ok I got the car to start by flooring it when I turned the ignition. The battery was fine. But I let it idle for a couple min and when I went back there was a lot of gas smell inside the car and when I opened the hood after that. Is that normal? WHat causes it?
Old Mar 1, 2003 | 06:04 AM
Rogo02SE's Avatar
WATER IN GAS
dry gas will help
Old Mar 1, 2003 | 06:48 AM
jaymode's Avatar
Originally posted by Rogo98SE
WATER IN GAS
dry gas will help
WHat do you want me to do? How do I drain the gas if it is wattery? There is about half a tank in there should I just go to the gas station and fill it up with premium then throw in some of that octane booster to get the octane up to where it should be if it has water in the gas?
Old Mar 1, 2003 | 07:01 AM
andreyyy's Avatar
just fill it up with premium and put some fuel injector cleaner,and maybe fuel system cleaner.
02PearlSE
Oct 7, 2015 02:12 AM
neilraz
Sep 11, 2015 07:36 PM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
Balkins
Aug 12, 2015 06:39 AM
