Brake noise from high speed...HELP!
Old Mar 6, 2003 | 12:15 PM
phenryiv1's Avatar
Mod her. Ate her.
The last 2 times that I have had to stop from high speed (80+), my brakes have made a "whump"ing noise...actually it is more like whumpwhumpwhumpwhumpwhumpwhumpwhumpwhumpwhumpwhump whump, but you get the picture. Do I have something wharped or do I need new brake components?
Help! BTW, I can possibly give more deails, but I do not know what might be important at this point.
Old Mar 6, 2003 | 12:33 PM
Dev's Avatar
Dev
Re: Brake noise from high speed...HELP!
Originally posted by phenryiv1
The last 2 times that I have had to stop from high speed (80+), my brakes have made a "whump"ing noise...actually it is more like whumpwhumpwhumpwhumpwhumpwhumpwhumpwhumpwhumpwhump whumpwhumpwhumpwhump, but you get the picture. Do I have something wharped or do I need new brake components?
sounds like warped rotors...
Old Mar 6, 2003 | 12:37 PM
phenryiv1's Avatar
Mod her. Ate her.
Re: Re: Brake noise from high speed...HELP!
I assume that that is bad...If I replace those, what else needs to be replaced with them?
Old Mar 6, 2003 | 12:45 PM
Dev's Avatar
Dev
Re: Re: Re: Brake noise from high speed...HELP!
you would probably want to get a new set of brake pads as well.
if there isn't that much braking power, your brake fluid might need to be changed cause it may have air or moisture inside of it.
Old Mar 6, 2003 | 03:51 PM
NyC97Max's Avatar
hmm...u have the sumitomo HTR+, it might just be those, cuz whenever i brake from above 80 or 90 mph or so rather hard, it makes a whirling wuhuhuuhhooo sound...it might be yur brakes but it can also be the tires, cuz these tires are prone to that kinda sound new or used
Old Mar 6, 2003 | 03:54 PM
seven's Avatar
HTR ZII's, same noise
these tires are good but noisy
Old Mar 7, 2003 | 06:11 AM
phenryiv1's Avatar
Mod her. Ate her.
I do not know if it is tires because I have never heard it before- only after a few hard stops I had to make last week.
Mar 12, 2020 12:06 AM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
Justin Kroll
Sep 2, 2015 11:06 AM
