Those of you that have installed MEVI
Re: Those of you that have installed MEVI
Originally posted by hacim105
Did you use any anti-seize or anything like that? What kind of lubrication did you use for the rod, etc?
I would get a new EGR and TB gasket though.
D
The butterfly rod on the VI has a low-friction coating on it that doesn't require any lubricant. I suppose a light (read: LIGHT) coat of lubricant can't hurt. I would shy away from silicone-based lube as it can ruin O2 sensors and you have no guarantee the lube won't get into the engine and out into the exhaust at some point.
FWIW, I didn't lube my rod (uh huh huh) and after ~15K miles, she still works like a charm.
You will have no more problem passing a smog test as you would with the stock intake manifold, as the test conditions are at a low enough rpm that the major changes in airflow won't even be seen (5000+ rpms). Even at higher rpms, I doubt (although don't know for sure) that the increased airflow would alter emissions that significantly. Since the Maxima uses a closed loop control mass airflow-based control system, any changes in airflow are pretty accurately accounted for via a change in injected fuel.
MaxLife17
06-27-2019 01:37 PM
