How to install FSTB and rewire corners...
Old Mar 19, 2003 | 04:15 PM
DerekJ212's Avatar
Anyone know where I can find this information?
Old Mar 19, 2003 | 04:17 PM
mzmtg's Avatar
Minister of Silly Walks
4th Gen FAQ
Installing the FSTB is the simplest mod there is.
Old Mar 19, 2003 | 04:22 PM
Zeks 97SE's Avatar
what about a custom
oil cap, or radiator cap ..now that may be the simplest mod .
Old Mar 19, 2003 | 04:25 PM
DerekJ212's Avatar
Yes, Im not dumb but Im wondering if i need air tools, cuz i feel like im about to break a socket...and what should i torque it to after?
Old Mar 19, 2003 | 05:12 PM
BOZOnPJs's Avatar
go to MAXIMA DRIVER and then click on the how2
Old Mar 19, 2003 | 05:25 PM
Dev's Avatar
Dev
how would you break a socket??????
you don't need a site...here it is:
take off the strut bolts...put on the fstb...put on the bolts torque to 30-40lbs
if you can't do this...good luck with your other mods
Old Mar 19, 2003 | 05:33 PM
Kashoggio's Avatar
Originally posted by mzmtg
4th Gen FAQ
i beg to differ... i think the clear corners are.. and maybe the Nissan racing shoulder pads
Old Mar 19, 2003 | 05:54 PM
DerekJ212's Avatar
The bolts will not loosen and applying all my strength could possibly break the socket. No need to be a smart ***...I could not find the torque spec quickly, thus I asked. Thanks everyone.
Put clears on and they look great!
Derek
Old Mar 19, 2003 | 07:45 PM
Speebs's Avatar
I aim to misbehave.
Derek
I'm pretty sure you don't want any more than 32 lb/ft of torque. I don't remember what Haynes recommends, but I don't think it was anywhere near 40.
Old Mar 19, 2003 | 08:01 PM
Kashoggio's Avatar
screw torque specs... everyone keeps trying to torgue every single freakin bolt in the car. I will be honest,, torque specs are nice and all but when a flat rate tech is working on your car he dosent care about that .. all he want is to get the job done and fast as possible and most of the time unless its like internal engine work he dosent care. Most tech go by these torque specks
PFT - petty f***ing tight
RFT - really F***ing tight
Old Mar 19, 2003 | 08:04 PM
Jamsan's Avatar
LOL @ kashoggio...
I broke a socket wrench trying to put on my FSTB....bolts were on there like wow....The wrench was pretty crappy tho...
Old Mar 19, 2003 | 08:06 PM
danimsta's Avatar
nail clippers
electric tape
phillips screwdriver
1. take the screw out for the corner light
( its located above the corner light, under the hood )
2. firmly pull the assembly from the car
( don't pull too hard, but you will hear it pop out )
3. remove the light(s) from the assembly & remove the bulb
( just turn the light in the opposite direction of the arrows )
4. take the pair of nail clippers and clip off the lower metal nub
5. wrap the bulb from bottom to just below the second nub
( don't wrap the other nub, or this light will not illuminate )
6. insert the bulb into the harness w/ the nub secured tightly
7. check the connection before putting the assembly back on
8. put the assembly back on to the car w/ the screws tightened
9. make sure the lights are secured in the correct manner
10. now you can see! it's a great improvement over stock
11. let me know if you have any problems!!!
props to z30maxima
this is a VERY easy mod, if u need help, just pm or im(I Am Danimsta) me
see ya
Old Mar 19, 2003 | 08:11 PM
Kashoggio's Avatar
Originally posted by danimsta
nail clippers
electric tape
props to z30maxima
see ya
i need some help with this...
Old Mar 19, 2003 | 08:29 PM
Speebs's Avatar
I aim to misbehave.
I'd prefer to torque to spec and avoid having to replace my struts, thank you.
And Haynes does say 29-40, but I believe most people torque to about 31-32.
Old Mar 19, 2003 | 10:13 PM
danimsta's Avatar
what part exaclty are u having trouble with?
drop me an email and we can talk more
danimsta@hotmail.com
Old Mar 19, 2003 | 10:44 PM
Dev's Avatar
Dev
Old Mar 19, 2003 | 10:49 PM
Dev's Avatar
Dev
Derek
how am i being a smart ***?
if what you're saying is true, then you cannot EVER remove the nuts on your strut tower because they will break if apply too much force?
well then you just answered your own questions - it cannot be done.
Old Mar 19, 2003 | 11:55 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
Derek
set your torque wrench to like 20 lbs, and remove the nuts, not bolts. When you put all your strength into it, you wind up moving it unevenly, applying force/pressure on the nut that will wind up stripping the thread. If you use your torque wrench, the wrench does most of the work for you. I know it sounds crazy, but i had the same problem, and it worked for me.
MaxLife17
Jun 27, 2019 01:37 PM
Sir Tilus
Mar 22, 2016 01:49 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
