Self Camber
Old Apr 11, 2003 | 10:39 AM
Tapio's Avatar
Self Camber
I'm installing Sprint springs this weekend and though most people say camber bolts aren't required I know it's possible, because of the slight play in the lower mounting bracked for the struts, to slightly adjust camber on your own. Question is..Which way do I need to adjust it? Does dropping a car cause the wheels to sit / \ or \ / when looked at from the front. Assuming I just push/pull on the bottom of the rotor when I tighten the bottom strut mount bolt to adjust the camber accordingly.
Old Apr 11, 2003 | 11:27 AM
njmaxseltd's Avatar
Make them go as far this way \ / as you can.
Old Apr 11, 2003 | 09:29 PM
ZeRo MaX's Avatar
i'm still lookin' for the answer how long (miles) can i wait to get an alignment after loweing... still haven't got a chance to aligned it yet...
Old Apr 11, 2003 | 10:16 PM
Keith P's Avatar
What is a set of tires worth to you? What about the next set?
Do you want predictable road handling?
matts95max
Apr 23, 2025 10:44 AM
Dan93se
Apr 7, 2001 02:46 PM
sachin98max
Feb 24, 2001 11:35 PM
I30CeFiRo
Dec 28, 2000 09:25 PM
ZuMBLe
Nov 1, 2000 07:39 PM
