problem, hearing a whining noise please help
Old Apr 15, 2003 | 06:16 PM
mikey62681's Avatar
I have a 95 auto maxima. when i'm driving between 20-60 mph i hear a whining noise (kinda like a turbo sound), it sounds like it is coming from the left side of the driver. But the thing is it only when i push on the gas. has this hapened to anyone and what kind can i do to fix this. Please help.
Thanks Mike
Old Apr 15, 2003 | 06:18 PM
fisher01's Avatar
Transmission?
Old Apr 15, 2003 | 06:20 PM
mikey62681's Avatar
how to you figure?
Old Apr 15, 2003 | 06:29 PM
Street Reeper's Avatar
Handsome
Re: problem, hearing a whining noise please help
Thanks Mike
Do you have a popcharger style intake? IF you do you are probably just hearing the air passing through the throttle body when it is part way open creating a whissle effect.
Old Apr 15, 2003 | 07:05 PM
fisher01's Avatar
Just a thought about possible transmission noise based on whining and location of sound. I had an older maxima doing something similar and after a 500 mile trip one day the tranny just went completely out, lost all gears, lucky it happen just as i got off interstate and was just a few miles from home. I drove all that way knowing transmission was whining away and almost made it home.
Old Apr 15, 2003 | 07:15 PM
99Maxima5sp's Avatar
if you have an intake...could be that...however my intake doesnt whistle from 20-60mph...that would get annoying...you cant hear mine until you get on it...But i do have a whistle at a certain RPM in the lower gears...sounds like a turbo (I WISH) spooling up, but on a quiter scale...
eric
Old Apr 15, 2003 | 07:31 PM
-MaxPayne-'s Avatar
Shorten your sig length, it's annoying to scroll so far .
Back on topic, my car whistled like that when I had an exhuast leak at where the y-pipe comes down from the motor.
-payne-
Old Apr 15, 2003 | 07:50 PM
mikey62681's Avatar
all i have is a K&N drop-in air filter. I don't know if it could be that. but i will check on an exhaust leak.
What is the easiest way to check for a leak. thanks for everyones help.
Mike
Old Apr 16, 2003 | 07:00 AM
XXXL Cracker's Avatar
Mike
Get a friend, open hood, have friend step on gas and rev engine( make sure you are in park or neutral). Listen for whining noise. If it is an exhaust leak it will be present always. If it is only present when drving, not an exhaust leak.
D
Old Apr 16, 2003 | 07:05 AM
breaux124's Avatar
How about Alternator whine? Is it coming from your speakers or from the car?
With your K&N filter, make sure the air box is properly seated. If the filter wasn't in straight there could be air leaking and creating the noise. Can you hear the noise with the windows open and closed?
Old Apr 16, 2003 | 07:31 AM
s0ber's Avatar
Check what he said, I have alternator whine and it sounds just like what you mentioned, could be your speakers fooling you :P
Old Apr 16, 2003 | 11:06 AM
-payne-
yeah, ill get right on that ....
eric
Old Apr 16, 2003 | 05:33 PM
MaxWolf's Avatar
my frankencar actually does that...it's right at 2000 rpms at 25 mph+ or so....it does sound pretty neat, but it's not supposed to be that way. I'm just gonna make sure my vaccum hoses are tight and go from there.
Old Apr 16, 2003 | 07:05 PM
maximasrule's Avatar
ok as the condescending bastard of maxima.org id like to fix your problem in effort to rectify my lost image. as your driving lift your right hand off the steering wheel slightly so its in the vertical position parallel with the side of the car (its roundish i know just keep with me on this one). bring it over to your chest and smack that chick in your passenger seat. the whining will stop for a moment. if it returns it will most likely be slightly loader. if so repeat as needed. don't worry its only a matter of time my friend. keep cool, later
dan
Old Apr 16, 2003 | 07:11 PM
s0ber's Avatar
dan
Old Apr 17, 2003 | 04:30 AM
dan
eric
boomerbrian
Oct 31, 2018 10:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
