Stillen Kit installation techniques?
Hey what up. I got this stillen kit finally in primer and im ready to install. So whats the best way to install it. I need something more than just a two sided tape. The sides will be easy but the front i wanna make it look factory. Any Really Good Ideas?
bolts/rivets/liquid nails?
The side skirts on the last kit I did required a lot of grinding to make them fit right. Screws are required to hold it in place and two face tape keeps it tight against the car. It's not easy to get the sides to fit really tight.
Good luck with it!
Good luck with it!
Good luck with it!
Good luck with it!
How did/CAN i mount the front.? I was thinking about boltin it on but im so scared of messing it up. I was thinking like 2 bolts on each side, on the inside where the center little plastic bars are.
any ideas?
Originally posted by bobjohnson
Grinding where? Like where the door shuts on the bottom?
any ideas?
hey thanks. how did you get your on. did you bolt it anywhere? besides on the sides
sides: I used 3M tape along the top(where it tucks into the doors). Then two screws in each wheel well and three across the top and two into the bottom.
rear: I carefully put 4 screws in each one holding it tight to the bumper. I also used 3M tape across it.
Originally posted by kj043
I found another 3M product called Heavy Duty Attachment Adhesive that seems like it would be stronger and more durable than the Double Stick Mounting Tape. Link Will it be better to use for installation? Or will the Mounting Tape be sufficient?
I will try to take some pictures when I get a chance.
MaxLife17
06-27-2019 01:37 PM
