CV Boots Replacement
Old Jun 22, 2003 | 09:13 PM
charliemax's Avatar
Anyone know if I have to drain the tranny before taking out the axle? I got some conflicting intructions on the net and from the factory service manual. Also, I've tried to pull the driver side axel out today with no luck, is there an easier way of doing so? I was also looking at my inner cv boots, they looked like they are about to go. Anyone know where I can get them for a good deal. Any other instuctions on this subject that you guys might have.
thanks
charlie
Old Jun 22, 2003 | 09:17 PM
danthediablo20's Avatar
Hmm my cv joints are out also..dunno how take them off either...any one help..got another question on my right passenger side when i turn the wheel either way it makes like a grinding noise like the tire is rubbing against the fender but it aint..andi cant find the problem myself anyone know wat it can be..Thanks
Old Jun 22, 2003 | 09:27 PM
charliemax's Avatar
dan,
is your cv boot out on the passenger side? have they been out for a while before you noticed it? if yes, then you have a busted cv joint. you might have to replace it. i caught mine before it was gone too far.
Old Jun 22, 2003 | 09:41 PM
iansw's Avatar
Just replace the whole axle.
Easier than replacing the whole boot, and doesn't cost a whole lot more anyway.
Old Jun 22, 2003 | 09:52 PM
i noticed it after i had installed my struts and springs..i just had it parked and turn the wheel and heard it rub..so i should just replace the both axles or just the right side only? but do i have to buy the cv boots also or does it come all together? The cv joint um around wats teh prce range on those and where can i get a good price on it?thanks
Old Jun 22, 2003 | 09:58 PM
charliemax's Avatar
check to see if the cv boot is ruptured first. if yes, then check to see the inside of the joint. if it is dried up or if you see rust in it, then you have to replace the cv joint. i saw one on ebay for $25. but you will still need to buy the cv boot. it is easier to replace the axle, but it's not necessary to replace both of them. but since you are already doing one side, might as well do the other. that's what i'm doing to mine.
charlie
Old Jun 22, 2003 | 10:24 PM
Jatan's Avatar
This might help a little http://www.motorvate.ca/mvp.php/401
- Jatan
Old Jun 23, 2003 | 04:43 AM
mzmtg's Avatar
Minister of Silly Walks
I didnt drain my trans when I changed an axle.
Old Jun 23, 2003 | 05:38 AM
sean96SE's Avatar
recently replaced both front axel assemblies and i did drain the transmission fluid first. i don't know if it's completely necessary for both sides but just wanted to be sure.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
