Underdrive pulley installation help
Old Jan 30, 2001 | 07:53 PM
Kevin Wong's Avatar
I spent 3 hours trying to get the pulley on. I loosened the idle pulley and removed the drive belt. I loosened the nut for the power steering belt, but it didn't loosen. When I tried to loosen the bolt on the power steering pulley, the whole pulley and the crankshaft pulley along with my tires would turn. I had a buddy hit the brakes, but it didn't do much. I think I'm going to hold out for an impact wrench.
any advice would be appreciated.
Old Jan 30, 2001 | 08:21 PM
OgreDave's Avatar
Damn :)
you got bored n went for it huh
Old Jan 30, 2001 | 08:44 PM
emax02's Avatar
If you have a 5spd put it in 5th gear,
and if you got a auto then I don't no,try doing a search maybe that will help you. Good Luck
Old Jan 30, 2001 | 09:03 PM
Daniel B. Martin's Avatar
Originally posted by Kevin Wong
... I loosened the nut for the power steering belt, but it didn't loosen. ...
There is a lock bolt and an ajustment bolt on the power steering pump. To slacken the drive belt you have to loosen the lock bolt and then turn the adjuster. Refer to the Haynes manual, page 1-16, photos 12.5b and 12.5c. See also http://integra.vtec.net/geeser/megamax/60k_service.html step 7, Belt Replacement. Click on the thumbnails for enlarged images.
Old Jan 31, 2001 | 06:37 AM
GregP's Avatar
I have detailed instructions for the UDP on my web site.
http://grprete.jnet.net
Old Jan 31, 2001 | 07:58 AM
DaEnigma's Avatar
I used GregP's instuctions Thank you GregP it was way to easy with your instructions... well except putting the smaller PS belt on man that was hard way to tight of a fit...
Old Jan 31, 2001 | 08:38 AM
GregP's Avatar
Glad to be of assistance!
Old Jan 31, 2001 | 01:41 PM
Kevin Wong's Avatar
Thanks a lot for your help
I think I'll try it again tomorrow. I've become quite good at getting everything off. I can do it in about 20 minutes. Well, yesterday wasn't a complete loss...I changed my oil, filter, and wheels.
Old Mar 29, 2002 | 12:47 AM
magic_max's Avatar
How about the power steering pump pivot bolt? The Chilton and Haynes manual talk about 3 bolts for the removal/installation of this belt. Btw, has anyone gotten to the power steering pump pivot bolt?
Thanks,
scott
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
2kmaximel
Sep 16, 2015 03:19 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Johnny9595
Sep 3, 2015 05:18 AM
