o/d switch problem / '97 automatic
Hello,
I have recently encountered a little problem. My o/d switch on my automatic has gone out. The o/d light is not appearing at all on the dashboard (except when I start it). Has anyone had to replace the switch within the shifter?
The car drives as if 'I have the o/d on'. Toggling the switch back and fourth does nothing. Any suggestions on how to replace the switch would be greatly appreciated.
1997 Maxima Se (automatic)
Thanks,
Arizonamax
Thanks,
Arizonamax
Same problem.. different start
Yup. I've got a 97 SE with the same problem. O/D switch does nothing. Therefore, can't get the Trans computer into diagnose output mode. Car drives with O/D on (1st thru 4th) all the time regardless of O/D switch position.
HOWEVER, and this is a large however...
The check engine light diag gives a 10-03 and an 11-01 code. Both have to do with the shifter position switch (or some such thing).
I just recently replaced this transmission myself with a salvage tranny (from a junkyard) with 70k on it. I'm thinking either the switch on this tranny is bad or the connector is not connected.
Anyone have any thoughts on this???
bryants95max
Oct 2, 2015 12:52 PM
