Checking ECU
Old Jul 21, 2003 | 09:43 AM
pscmj84's Avatar
Checking ECU
Two questions:
When you turn your car to on, is the check engine light supposed to come on? Mine isn't.
When you turn the ECU screw, you're supposed to feel it stop right? Mine just seems to keep spinning without feeling like it wants to stop.
Old Jul 21, 2003 | 12:41 PM
pscmj84's Avatar
After this, I tried starting the car and it would just stall, so I turned it to counter clockwise for a bit, then it started and didn't stall. The engine felt weak. I tested 0-60 and it was 9.5, 2 seconds slower than what I have gotten before. I the screw counter clockwise some more, then the engine felt back to normal, also the check engine light now comes on when the key is in the on position, I was relieved. Just to make sure everything is back to normal, what position is the screw in when it is normal (as in, what angle is the hole where the flathead goes?) Sorry if this sounds confusing.
Old Jul 21, 2003 | 01:09 PM
njmaxseltd's Avatar
The screw slot should be vertical. (up & down)
Old Jul 21, 2003 | 01:42 PM
slizan99's Avatar
make sure to be careful when you adjust the screw. overturning it will cause damage to your ECU.
gustavison
Oct 4, 2015 06:50 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
