acceleration wierdness
I posted a thread not long ago about a wierd noise that I encountered during moderate acceleration while pulling the rpms through about 3.5k. There was also a noticable power loss all around from where it has been, in particular near the top end. I recently hit 100k miles and the problem is becoming more persistant. the noise is noticably louder when i pull through the lower rpms and I know that its not just my ****-obsession that there is always something wrong with my car because my roomate noticed it too. Anyway, I tried pulling codes, and the ecu says nothing is wrong. so Im wondering what it could be, I will be taking it in, but id like to know what you guys think first. thanks
Originally posted by maxima_se007
could you describe the noise... or get a little more specific...??
The carrier bearing is mid point on the passenger side axel. It supports and holds the axel in place. Three bolts and some prying will seperate the bearing which is part of the axel. You can't replace just the bearing, you must replace the axel if it's gone bad.
Need help
23
10-02-2015 08:56 AM
