Tranny died AGAIN?!
Old Sep 4, 2003 | 07:40 AM
nadir_s's Avatar
vicodin ... gift of life
Tranny died AGAIN?!
i start up car in the morning... i notice that the clutch feels way too light. Like when I push it it in, there wasn't much force required to do so as there was before.
I have an Exedy clutch btw... so then the car starts up, but it refuses to go into any gear. blah! well, i still have warranty from the repair, but I hope they don't blame the clutch and make me pay for the repair. Can anyone shed some light on what the problem could be? Thanks!
btw- i did look for leaks, but I didn't see any under the car. The car ran fine yesterday... no problems.
well, gotta take the other car to school... please help guys.
Old Sep 4, 2003 | 07:45 AM
Stephen Max's Avatar
Sounds like a clutch master cylinder or slave cylinder problem, or maybe a clutch hydraulic fluid leak. Did you check the level of fluid in the master cylinder? Will the tranny go into gear with the engine off?
Old Sep 4, 2003 | 07:54 AM
wrongway15's Avatar
does the clutch pedal return back up?
Old Sep 4, 2003 | 10:07 AM
Ramius83
If the tranny was put in with a new clutch, then you can probably rule out those two components considering they are both so new. I would guarantee you that this is a clutch line component failure, ie. master cylinder, slave cylinder, line, etc.
Old Sep 4, 2003 | 11:14 AM
nadir_s's Avatar
blah that's what i thought... looks like i gotta spend more money
The clutch does return back up... it's just when I press it down, it feels all weak and soft.
AND, i'm ruling out the transmission because I can shift gears w/ the car off and my foot off the clutch.
I think I remember the tranny guy mentioning something about how the clutch cylinder doesn't look good or whatevers.
I'll check the resevoir... can this thing be replaced w/o the tranny being dropped?? How much would I be spending?
THANKS ALOT guys, i reall appreciate it
Old Sep 4, 2003 | 01:04 PM
96shogunmax's Avatar
problem solved..
Old Sep 4, 2003 | 01:18 PM
Nismo's Avatar
yes you can replace the whole hydraulic system without dropping the tranny. the resovoir your talking about is the master cylender
Old Sep 4, 2003 | 01:22 PM
JAY25's Avatar
you can also check to see if the fork that holds the TO bearing, is still aligned and holding the TO bearing in place
Old Sep 4, 2003 | 09:11 PM
nadir_s's Avatar
96Shogun max's advice did the trick!!
Both Hal and him knew that I was low on clutch fluid... i went out and checked and they were right. Then shogun told me to get some brakefluid Dot3 and fill it up... which I did. I pumped the clutch for a long time afterwards and voila! it felt normal again, and I can drive the car around! yaaaay
now I gotta find where the leak is.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
maxima297
Sep 30, 2015 03:32 PM
pktaske
Sep 4, 2015 08:40 AM
