My Trunk is sticking
Old Sep 16, 2003 | 01:59 PM
zealotnyc's Avatar
My trunk recently won't open with the remote OR the button under the driver side door. The only way I can open it is manually with a key, thing is, when I remote open it, I hear a clunk, like it's functioning but it won't open. Anybody else have this problem?
Old Sep 16, 2003 | 08:07 PM
MaximusMax's Avatar
I had the same problem...here's how I fixed it.
1) Open your trunk
2) Where the bottom latch is, there is a long piece of plstic, right by the bumper. Take that off, then you can get to the actual latch.
3) There is a cable that has to connect to that latch from the left (you should be able to figure that out).
4) Be sure everything is tight, bolts, and all
That's how I fixed it. Hope that helps.
Old Sep 16, 2003 | 08:08 PM
zealotnyc's Avatar
thanks a lot man, i'm gonna do it first thing in the morning, as i don't wanna get eaten alive by mosquitoes
Old Sep 16, 2003 | 08:30 PM
MaximaEvolution's Avatar
In my trunk, there is a manual switch if you put your head inside the trunk and look down at the latch. You should see a little lever. It may have accidentally been switched, if you even have this on your model, i am unsure. Check it out before taking the harder route. I read in the manual that that switch disables every way to open the trunk, except if you use the key
Old Sep 17, 2003 | 12:45 PM
slfalco's Avatar
Absolutely check that little lever, happened to me when something i was carrying in the trunk flipped the little lever... Felt dumb when I finally read the owners manual....
REDinLV
Aug 15, 2024 12:30 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
