Emblem Shaving
Old Sep 18, 2003 | 08:00 PM
tranz's Avatar
Emblem Shaving
I understand how to do it. The problem is that i worry that my 96' Maxima GXE will leave a stain or the paint is burned in. I am worried that the MAXIMA will leave an imprint in my sterling mist paint. Should i worry about it?
Old Sep 18, 2003 | 08:09 PM
Keith97gxe's Avatar
i wouldnt worry about it, mine is pebble and its fine i would think you would be ok
Old Sep 18, 2003 | 08:54 PM
tranz's Avatar
I'd think that if it is a really old paint job (8 years) it may leave a mark behind that cannot be fixed.
RA030726's Avatar
I'm nutty for Nissans
I can still read maxima on the trunk. but i think its b/c i rubbed so long and hard and used dare i say it.......a paper towel
Old Sep 18, 2003 | 09:35 PM
MaximaZX's Avatar
just remove the emblems, remove the glue with some goo gone (worked well for me). then go over it with a buffer, there MAY still be slight color difference, but that should soon vanish, and worse case, you have to put the emblems back on...
Old Sep 18, 2003 | 09:44 PM
99Maxima5sp's Avatar
Yeah, pretty much. My friends 96 had that happen, if you look at it with the right light hitting it a certain way, you can still make out MAXIMA, but you have to know what your really looking for. Thats why i just shaved the burger off, and left maxima...
Eric
Old Sep 19, 2003 | 07:03 AM
ch13f's Avatar
If there is any trace of the letters, just go over it with some scratch removed and then a coat or two of wax. You'll never even know they were there.
Old Sep 19, 2003 | 11:49 AM
Jatan's Avatar
I see you live in Glenview Check out the "Regional" forums
I'm about to do this on my white Max and I know it'll leave an imprint on it. It should go away after a while, if you wash and wax it normally.
I tried it a few weeks ago, but the fishing line broke Need to find a stronger fishing line...
Atleast take off the Nissan hamburger in the back! I'm taking off everything in the back since my emblems are gold and now they're dirty and gay looking. For me, it'll look better with it off
Just like ch13f said, the worst thing would be is that you would have to put them back...
Old Sep 19, 2003 | 12:23 PM
Ladzio's Avatar
Sorry, I am a , what is the best way to take those emblems off, not pry them out I guess..
Old Sep 19, 2003 | 12:31 PM
maximumspeed's Avatar
I used Dental floss to shave mine off,works great
97 MAXIMA SE
Old Sep 19, 2003 | 02:51 PM
tranz's Avatar
ok now that i have removed it, i can see little remains of the m's and a's. Is there anyway to get rid of it? I cleaned the adhesive off so now what should i do. I can see these m's and a's outlines at certain angles.
Maybe the sun will eventually burn those colors in?!
Old Sep 19, 2003 | 05:24 PM
kenji's Avatar
Try using a clearcoat polishing compound to clean it up a bit. This made my rear look flawless and you can't tell any of the emblems were there on my 95 pbm max
you should be able to find this at any 'everything store' like walmart or kmart etc.. if not, you can find them at any auto part store
Old Sep 19, 2003 | 05:56 PM
Jatan's Avatar
It'll go away after a few weeks when you wash it regularly. Clay bar it and do what kenji said.
How did you do it?
Old Sep 19, 2003 | 08:15 PM
Ladzio's Avatar
Thank you maximumspeed!!! That a good idea, I tried to use fishline today that found in the garage, but it kept ripping. Dental floss should work!!!! Will do it tomorrow!!!
Old Sep 19, 2003 | 09:13 PM
You're welcome if it rips just roll off some more out of the container
Old Sep 20, 2003 | 08:06 AM
MaximaSE96's Avatar
Maxima Owner
if it stains get some rubbing compund and rub it out by hand
Old Sep 20, 2003 | 02:46 PM
kyle13's Avatar
I took mine off just now to discover to my horror that the paint was peeling and chipping under my burger. How do I put it back on? When you buy them to they have the adhesive on them?
Old Sep 20, 2003 | 03:19 PM
Jatan's Avatar
Go to an auto store like AutoZone or PepBoys and look for the emblem adhesive/glue. Just put some behind your emblems and stick it back on your car.
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
05RLS2
Nov 7, 2016 05:52 PM
DBear
Sep 14, 2015 08:33 PM
rbaker100
Sep 6, 2015 02:46 PM
