engine trouble...code 0403.
Old Sep 27, 2003 | 10:08 AM
icheban26's Avatar
last night my car shut off while i was driving home n white smoke was coming from the engine...got it towed home n this morning when i started the car everythin is fine except the check engine n battery light is on. i checked n got the code 0403 which is the throttle position sensor. my question is how hard is it to replace n wat tools is needed for this job??
TIA
icheban26
Old Sep 27, 2003 | 11:46 AM
2naboy's Avatar
The best and perhaps the easiest way to do this is to take the throtle body out which allows easy access to the TPS. There are two philips head screws that hold it down.
Old Sep 27, 2003 | 01:20 PM
Kevlo911's Avatar
Kevlo for President
www.newnissanparts.com should have one NEW OEM one for cheap or buy one from www.car-part.com ( online junkyard)
Old Sep 30, 2003 | 01:49 PM
time2reup's Avatar
did you test it to make sure it is actually bad?
Old Sep 30, 2003 | 02:44 PM
icheban26's Avatar
no, i didn't...i had my friend checked it out n he told me the cause of the problem was the alternator n not the sensor itself. i remembered that my car had a alternator recall couple years ago...should this still be covered???
Old Oct 1, 2003 | 07:05 AM
time2reup's Avatar
I think the alternator recall was vin specific....there is info on it here somewhere...if you are covered you should be able to just call the dealer and let them know you need to get your's replaced under the recall...
Old Oct 1, 2003 | 02:35 PM
icheban26's Avatar
i just called n they told me there is no recall...i think my car should be one of the bunch that should be covered. when my car hit around 30k miles my engine died n i had the alternator replaced under warranty, at around 55k they send me a letter notifyin me of a recall...i bought it in n they were done w/my car in less than an hr...so i don't know if they replaced a new one or not...now at 90k the alternator is mess up again...grr.
so wat do u think...should it still be covered even though i brought in my car to had it look at durin the time of the recall which is couple years ago.
Old Oct 1, 2003 | 02:42 PM
ivelweyz
the recall was for 98 maximas...
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
