very big problem...
Old Oct 13, 2003 | 07:10 PM
zzzwilliams3200's Avatar
very big problem...
ok guys, 96 maxima 145,000miles, i had error codes for knock sensor and for coolant temp sensor, I just changed the KS today and right after I cleared the error codes I start it up and it idles very low about 400rpm, if I rev it up a little it hesitates, and then dips very low, and if at this low point I open up the throttle to bump it back up, I hear a knock from the engine which sounds like bad pinging. But above 1000 rpm its fine when I drive it but if I let off the gas it goes to about 200rpm or stalls and takes a long time to restart (10-20 seconds) and that is working the gas pedal a little which seems to help it start. I drove it a few miles and so far no CEL yet. I have had this stalling problem before I changed the knock sensor but it seemed to come and go, now I can't get it to even run right for a little bit....I am stumped so if anyone has any ideas I'd love to hear them. thanks guys.
Zach
Old Oct 13, 2003 | 07:37 PM
Ceasars Chariot's Avatar
Old Maxima Legend
get your throttle body cleaned. My car used to stall at a redlight quite often, I got a tune up a few months back and haven't had a problem since....
pinging - change ur gas ? I was getting some pinging but changed gas stations and haven't noticed anything now.
Old Oct 13, 2003 | 08:26 PM
I am gonna clean it right now, also...when you have the key to the on position, do you guys get 3 quiet ticks? this happens to mine while the engine is and while it isn't running. also i am looking to find my EGR valve, could someone direct me to find it cause i looked in the haynes book and i can't seem to find it anywhere. thanks
i tried changing gas and it doesn't seem to help
Old Oct 14, 2003 | 05:00 AM
i cleaned the throttle body and started it up and it ran fine until it warmed up, then it would idle about 300rpms. any other ideas? EGR?
Old Oct 14, 2003 | 01:32 PM
Kevlo911's Avatar
Kevlo for President
clean hte IAC vavle, how to is in my sig under 4th gen how to
Old Oct 14, 2003 | 01:52 PM
SpeedCrazie's Avatar
You should have replaced the Engine Coolant Temp sensor FIRST.
Sometimes, other codes appear as a reaction to other problems, in this case the Engine Coolant Temp caused the code for the KS.
Once upon a time, I also had this problem, and the hesitation and stalling, as well as the long starts are all symptoms and signs of the ECTS.
Get that replaced, DIY not hard doesn't take long.
Good Luck.
JP
Old Oct 14, 2003 | 01:57 PM
LastBoyScout's Avatar
Originally Posted by SpeedCrazie
My Car is going to be the craziest new car in town.... I really need to get a website to show all of my pics. Wont it be sweet??
Yes.......yes it will
Old Oct 14, 2003 | 02:01 PM
Jatan's Avatar
What did you do with the coolant temp sensor problem? Is your intake stuff nice and tight so there is no air leak?
Make sure you have all your connector things tightly plugged in. I accidently didn't push in the MAF sensor connector in the all way before and I had low end lag. Now when I sprayed some more TB cleaner into the TB yesterday, I plugged it back in tightly and now my low end is back
Old Oct 15, 2003 | 10:56 PM
LastBoyScout:
Did you make that quote??? Cause I know I have never said such a thing...but complment...Thanks.
JP
Old Oct 15, 2003 | 11:01 PM
SXN's Avatar
SXN
LastBoyScout:
JP
well it IS gonna be nice , any update pics?
Old Oct 16, 2003 | 09:28 AM
maguero's Avatar
Zach
This describes exactly the problem I was having a few months ago. I decided to change the coolant temp sensor first b/c it cost less than $20 and is easy to change. Once I changed it, everthing was back to normal. Check engine light is gone, and there is no stalling. Good luck.
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
