"Clunk" noise when turning wheel or hitting bumps
Old Oct 15, 2003 | 06:31 AM
maxsthebest's Avatar
I have been experiencing a "clunk" noise when I pull out of my driveway and then turn the wheel back to the right to drive out. I hear the same noise, on occasion when breaking, or when hitting bumps. I seems to be coming from the front end passenger side. Anyone had similar problems with this?
Old Oct 15, 2003 | 10:55 AM
99Maxima5sp's Avatar
Yeah, i hear a clunk noise, but it has to do with me being lowered and my struts blow to all hell....
Are you lowered or anything?
Eric
Old Oct 15, 2003 | 11:25 AM
SLOW96MAX's Avatar
Maybe a cv joint?
Old Oct 15, 2003 | 12:37 PM
jt151's Avatar
Yeah, I get the same clunk noise from the passenger side whenever I come over a bump a little faster than I should. I've got a 1.3 drop on my car.
Old Oct 15, 2003 | 12:47 PM
MrEous's Avatar
^ Jeff™
If you're lowered it is most likely the spring or strut...check the strut for failure or check to see if the spring is set correctly in its seat.
Otherwise you should also check the cv joints for rips in the boot or signs of leaking.
Old Oct 15, 2003 | 12:54 PM
Jatan's Avatar
It could be the front strut bearings, axles, or your suspension is not seated properly
Old Oct 15, 2003 | 01:07 PM
hacim105's Avatar
I know mine isn't set properly and it is really ****ing me off to hear the clunking noises. I should really go and fix it sometime.
Old Oct 15, 2003 | 01:46 PM
ChrisA's Avatar
sounds like CV to me. i'm doing mine this week myself for the first time.
Old Oct 15, 2003 | 03:38 PM
perfectmax's Avatar
Nissan charged me $450 to replace the cv boots. I also have a crunching sound over bumps but my car is lowered. I think that the spring isn't seated right.
Old Oct 15, 2003 | 07:09 PM
quickie's Avatar
How can you find out if you have a blown strut?
Old Oct 15, 2003 | 09:47 PM
Nismotic's Avatar
Always sunny in philly
jack the car up from suspected area, take a looksie inside...you'll know it's blown to hell when you got grease leaking everywhere...
Old Oct 15, 2003 | 11:10 PM
perfectmax's Avatar
Not ness true kid. I blew my front left KYB AGX and there was no leakage. It is easy to tell if a strut is blown. Your car wont handle as well, and the car will spring around when you push down on the corner of it.
Old Oct 16, 2003 | 07:02 AM
My car is not lowered. I did have a ripped CV boot and just had it repaired. Unless of course he didn't check to see if the joint was OK.
Old Oct 18, 2003 | 02:53 PM
pjalst
is it hard to replace, any special tools needed.. I think this is my problem too. only I sounds like the noise speeds up as i accelerate, then fades away. sounds like it's coming from right under the dash. anyone?
Old Oct 18, 2003 | 03:06 PM
Jatan's Avatar
CV check
CV replacement
Old Oct 19, 2003 | 12:45 PM
jetblack5spd's Avatar
i hear the same noise, but ive been hearing it since i got my car. now that im lowered, i hear the clunk sound more. OH YEA IT ONLY HAPPENS WHEN IT RAINS OR IF ITS WET OUTSIDE?????? IM STILL CONFUSED AFTER ALMOST A YEAR.
Old Oct 19, 2003 | 04:47 PM
pjalst
Maybe you should move to a dry state like Arizona or Nevada
Old Oct 20, 2003 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
Could be a power steering leak tht propagated tolower control arm bushing damage. Power steering could leak down and damage the bushings, therfore eating away at the bushing to where it clunks metal on metal
trasmadean
Feb 1, 2017 08:20 PM
official_style
Aug 29, 2015 10:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
jhontelj
Aug 17, 2015 04:07 AM
